Old 01-27-2016, 12:04 PM   #71
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: Roller Cams in Stock Eliminator?
How many of you guys AREN'T using some form or brand of racing oil? Which all have the proper additives and such for flat tappet use. The issue is that many are running roller spring pressure on flat tappetts. You want a roller, go to super stock and get the intake that goes with it!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 01-27-2016, 12:07 PM   #72
Billy Nees
Liked 7,799 Times in 1,747 Posts
Originally Posted by sammy pizzolato View Post
Like Mike said is true!!! the cost and time is unreal we need to ban together and loby for roller lifters. the big problem is the oil it's not there any more with all this EPA crap the world has gone in the tank. when you talk to the Cam people they won't sell cam's to the public without being a roller because of the oil. and the spring Pressure is not the problem!!!!!!!!!! it's the oil.
Yeahhhhh, no the problem is the spring pressures and the lobe designs.
Billy Nees 1188 STK, SS
Old 01-27-2016, 12:41 PM   #73
Run to Rund
Liked 54 Times in 27 Posts
As noted above, most of the cam/lifter failures could be avoided if max spring pressures were something like 170 seat, 400 open. That limitation would force more lobe profile development, I suppose, but the current combination of square lobes and 550 lb open doesn't have longevity.
Old 01-27-2016, 01:23 PM   #74
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Post Re: Roller Cams in Stock Eliminator?
OK see one idea of 170lb/400lb Open..
Looks reasonable..ANY other feedback...?
What is the breaking point?
I am on the NO Roller Lifter side of the argument and No Roller Rockers.
Will Stock Stamped Rockers should survive this rating?
Already saving money !
Should we also Limit Retainer Height to say 1.80 inches?
Are many cams exceeding 550 inches lift?
Most seem to be in the .400 to 450 inch range..
IHRA and NHRA has to be watching this !
Dan
Old 01-27-2016, 01:46 PM   #75
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Too hard for NHRA to check open pressure because all cam lifts are different..........
Set an installed height valve spring pressure limit of around 150 pounds....
Have NHRA buy an LSM valve spring testers to check installed pressure with the spring installed on the head and if the spring doesn't pass, remove it, measure installed height and use a RIMAC to confirm the pressure......
Looks pretty easy......
NHRA could even spot check the pressures....Only have to remove a valve cover...
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 01-27-2016, 01:53 PM   #76
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Well, let's look at it from the $$ side of things since that seems to be of interest.
Switch to roller cam = new billet cam, new roller lifters, new push rods, new valve springs (after all, what's the limit?), camshaft movement limiter of some sort, roller rocker arms, and then add in the machine work to allow the new maxsize valve springs that will be the next on the list to be allowed.
Reduce max seat pressure to something that will live with flat tappet lifters = new cast cam to work with the reduced pressure, new flat tappet lifters, new valve springs.
If you are smart, lobby for spring pressures that will allow common auto parts store parts to live. But I forgot, it takes too much to figure that out.
Old 01-27-2016, 02:18 PM   #77
Pvt Parts
Pvt Parts's Avatar
Dan
I really don't see what all the crying is about. It seems that the rules are doing what they are supposed to do... limit the cost and performance of a Stocker. The guys who are hurting parts are pushing the components beyond their limits.
Choices:
1. Back off on the cam/lifter issue and find more ET somewhere else.
2. Do whatever it takes to solve the problem. Exotic materials, different lubrication, different cam combination. If you can fix the problem, you'll have something no one has. And we all know that the cream rises to the top.
I do believe however, that valve train components should be consistent across the board. Allowing the older cars to run the same cam/lifter as the new cars would level the playing field.
Old 01-27-2016, 02:20 PM   #78
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
You guys are killing me with this spring pressure BS. nobody will change there cam profile, nobody wants to give up power....unless of course, you are bracket racing, Oh I forgot, that's what it is, because everybody bitches when somebody runs it out the back door.
back to the subject...you guys want to see a ton of broken valvetrain parts...limit the spring pressure and you will
next you will want an rpm limit
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 01-27-2016, 02:22 PM   #79
Bill Diehl
Bill Diehl's Avatar
Choices:
Excellent post
Old 01-27-2016, 02:27 PM   #80
kansas stocker
Liked 249 Times in 48 Posts
Funny how we ran for years with stock spring pressures and it was easy to check.
Times will be slower and nobody will be able to tell the difference except in their pocket book.
Pete
kansas stocker is offline   Reply With Quote
