#81 |
Liked 24 Times in 13 Posts
Looks to me some racers are making a case for taking the rules backwards and others are for moving forward toward overall engine safety. The point we can all agree on is everybody understands and accepts the problem but have differing viewpoints on how to correct them.
Maybe it's just me but my belief is once you start down a path you must be prepared to reach the end as long as the overall spirit of the rules are never compromised. Opening the duration rule, no limit on valve spring pressures, roller rockers, wild valve jobs, aftermarket oil pans, etc have been good things, and in my opinion, have keep Stock Eliminator from getting rather boring. Does anyone really want to see and A/S car slow down a half second or more? Another issue is Tear Down. Does anyone really believe the tech department wants to increase the time it takes to check camshaft duration, valve spring pressures, etc? I would doubt that very seriously. For what it's worth my 2 cents is the path forward is a far cheaper fix for the current camshaft/lifter mess and therefore rates superior to turning around and heading backwards with the rules. Retreating with the rules would be far more expensive not to mention it would be a waste of valuable time for us- as well as the tech officials.
Mike Keener A/S B/S C/SM |
#82 | |
Liked 7,807 Times in 1,748 Posts
Please humor me for just one minute and tell me just what it is that you think is left in your combo that you think is remotely "Stock" at this point! I know that I'm going to piss off a few real good friends here but the 396/375 combo is the LEAST "Stock" combo out there. You've gotten everything that you've needed over the years to make it faster and more dependable(and let's not forget the "easier to get parts for and less expensive" B.S.) and you just keep on wanting more! It seems to me that the issue here is either live with the rules that we've got(or at least the "spirit") and break stuff to go fast or back it down a bit and make it live. OR just go the heck back to Pro Stock or Top Stock!
#83 | |
Liked 184 Times in 113 Posts
More addiction creep away from concept of Stock. Eventually create new reliability issues. Hence the moose call of SSer opinions...."move to SS then" Before the Spring/Cam rule Stockers could not run with SS. Stockers now run well under the SS index. Think time to take a sensible step to go forward. What is the ROI here...!! Just My Two Tenths err cents ! D |
#84 | |
Liked 8,048 Times in 1,529 Posts
#85 | |
Liked 19 Times in 11 Posts
#86 | |
It is a good one with different POV with mutual consensus. As for the knowing the Rules, they change often. Yeah the trick is to moderate Spring pressure and still go fast. Figure putting a little Stock back into Stock is a good idea. In the 70s a M/SA car ran 13.30's, 80s 12.50 and today 11.80. Good night all D |
#87 | |
Liked 52 Times in 17 Posts
Does anybody know what the, before roller, spring pressures were on a Nascar CUP car?
Bernie Cunningham 7053 STK |
#88 | |
Liked 9 Times in 8 Posts
there is a thought ..lower the pressure so you can spend thousands of dollars on spintron testing.......what a concept ![]()
__________________ Bill Diehl B200 C/D STK |
#89 | |
#90 | |
Top Fuel and FC are running 1000ft. Pure Stock is a Solution too! They are work-arounds. |
