#11 |
Thanks Guys,
I'm just asking because I have these parts , see attachments, from another car, and was wondering if they would be ok, as they are needed on the car I want to make into a Pure Stocker. They are all bolt on type. If not, I would then have to enter a standard stock class correct? As well I have frame connectors on it. And front bolt in suspension where I couldn't find an link http://www.summitracing.com/int/part...003h/overview/ |
#12 | |
Liked 184 Times in 113 Posts
These are just fine. They bolt on and do exactly what the originals do. Except more robust..! D |
#13 |
Liked 216 Times in 77 Posts
#14 | |
Dick Miller sells them for most 4 link GM cars. Has others for Ford and Chrysler. They are bolt on and no welding. Been this way for decades. I am considered a set Upper Control Arm brackets. Which will change the angle of the Upper Control Arm on my b-body. D |
#15 |
FWIW.
Very few rules are different between Stock and Pure Stock. A or B Pure Stock may need similar safety equipment from M Stock and above. Such as a Roll Bar and Safety Harness. Pure Stock are the older 70s 80s Stocker rules. Safety still rules! D |
#16 | |
on lower rlb
Gary Burr IHRA MEMBER # 1958 Stk 1949 |
#17 | |
No, on lower Rib !! To settle it ... Email Mike Baker at MichaelBaker@LiveNation.com This is his latest email address. Then let us know what he said. Dan D |
#18 |
Liked 70 Times in 29 Posts
i can't see where that type of suspension would help this car especially if it will be an automatic. If you have good bushings in the stock control arms, that is all you need.
Put some new shocks on and some good slicks or drag radials and it will hook anywhere you race. By changing all of that, you are getting away from the intention of the current pure stock. If pure stock is meant to be an entry level class, you certainly don't need to spend $800 on those parts. They look to be too adjustable for the way the rule book reads anyway.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#19 | |
Regular Stock and Pure Stock rules are near identical. We are allowed a 3/4 inch change forward or rearward. In my case to be able to add 30 inch tall slicks without interference. As for good bushings...oh yes. Stock ones with a bunch of miles on them will get the crap beat out of them drag racing. Again chassis upgrade parts are more for safety and reliability. D |
#20 | |
Liked 308 Times in 103 Posts
On my car have urethane bushings and boxed stock control arms. Mike Taylor 3601 |
