Old 03-07-2016, 03:31 PM   #1
JP Schuster
Default Pro Tree T-Brake Vs. Full Tree T-Brake in SS
Is there a performance advantage to using a certain kind of transbrake in Super Stock?
JP Schuster is offline   Reply With Quote
Old 03-07-2016, 05:42 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: Pro Tree T-Brake Vs. Full Tree T-Brake in SS
When I went from a old TCI valve body to a Griner valve body I was .035 faster with Griner. Everything else in car was the same.
Old 03-07-2016, 08:46 PM   #3
Ed Wright
Ed Wright's Avatar
I have had three transmissions in mine, I won't name the other names, but whatever the Smiths put in my Pro Trans is faster than the other stuff I had. Only button I can find slow enough, even using a blinder, is the Just-N-Time button.
Best transmission I ever ownned as well.
Ed Wright 4156 SS/JA
Old 03-08-2016, 08:26 AM   #4
JP Schuster
Do you guys mean faster in reaction time or ET?
Old 03-08-2016, 11:48 AM   #5
Bobby DiDomenico
Liked 101 Times in 52 Posts
Is "faster" by dumping the reverse fluid quicker?
Old 03-08-2016, 12:44 PM   #6
Jeff Stout
Faster in reaction time. I had to adjust more travel in button. To many redlights
Old 03-08-2016, 02:05 PM   #7
Ed Wright
Ed Wright's Avatar
The Pro Trans made the car faster, but I was referring to my lights. Suddenly going red with my old button.
Old 03-09-2016, 08:27 AM   #8
JP Schuster
Okay thanks guys!
Old 03-09-2016, 04:23 PM   #9
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Default Also - you can make your own adjustable button
When I raced super-gas I made my own trans brake buttons from surplus snap switches available at a local electronic store for about $2.50 a piece.
This is a similar one that can be ordered for about $9.00. I just made my own shims to change the length of the button travel. I could red light easy when used with little travel.
Old 03-12-2016, 11:07 AM   #10
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Pro Tree brakes are typically fluid exhaust , meaning they rely on line pressure to move the valve when the solenoid releases . .....They are really intended for the Super .90 classes . makes it hard to not go red on a full tree .
They typically us much higher line pressure than a spring actuated valve .
Higher line pressure = more HP consumption = slower ET's !
