Old 03-29-2016, 01:31 PM   #21
pmrphil
Liked 397 Times in 153 Posts
Default Re: A follow up to "oil starvation issues" thread
I do see that the crank is burned only on one side, and not where the oil hole is. If it wasn't bent or cracked before, it's at least one or the other now. I don't recall if you said you had it checked for straight/cracks before.
Phil Molski
PMR Performance
S/C 1623
Old 03-29-2016, 02:47 PM   #22
joespanova
Liked 13 Times in 11 Posts
OK.......
Some of you guys called it correct when you suggested the crank is cracked..........FPI / MPI , whatever you want to call it , shows a crack in the radius near the worst damage................I didn't see it as it was already removed from booth when I got there.
So I finally bury my crank ( did I just say that?).
Now I'm looking at Lunati and Callies.
Old 03-29-2016, 02:51 PM   #23
joespanova
Glad you caught it before things turned into shrapnel. Amazing how the rod brgs. look perfect and the mains are hammered. Aeration, too much oil upstairs, an internal leak...likely a combination of things. Are you going to change where you source the vacuum or eliminate the pump all together?
I am reducing vac to , say , 6-7in , adding a balance tube to opposite side. I'll still pull off valve cover.
Old 03-29-2016, 07:53 PM   #24
carl hinkson
Liked 18 Times in 10 Posts
If your going to the Callies crank check into the Magnum XL with a Rem finish these are some of the pics of the crank I got for Jake Stelters build. That engine runs 8800 RPM and won Drag week 2 years in a row.
The short counter weights are the way to go alot less windage at high RPM's
http://s172.photobucket.com/user/bel...ml?sort=3&o=91
http://s172.photobucket.com/user/bel...ml?sort=3&o=92
Some pics of the oil pan.
carl hinkson is offline   Reply With Quote
Old 03-30-2016, 06:35 AM   #25
joespanova
Thats some crank he's got right there.........
Seems the trend is away from screens now a days........so which pan is he using? I have the 21017 with the tray in the "pic".
Old 03-30-2016, 07:58 AM   #26
carl hinkson
Jake is on F/B
Old 03-30-2016, 09:02 AM   #27
Ed Wright
Ed Wright's Avatar
Nice Super Stock crank! LOL
Ed Wright 4156 SS/JA
Old 03-30-2016, 09:32 AM   #28
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
How much does that crank or whats left of a crank weigh?Is that titanium rods? Would have to be light rod and piston combo to balance,but on other hand has a lot of weight removed opposite of counterweight also.
Joe I say crank was your whole problem,hope it gets better from here for you
Mike Taylor 3601
Old 03-30-2016, 09:58 AM   #29
joespanova
Mike Taylor 3601
Mike I 'm just wondering when it was cracked and for how long.
But I still cant see WHY that caused the condition above? Ok , so it ( assuming it may have been ) was cracked..........
Flexing / moving around........... would do that?
Old 03-30-2016, 01:17 PM   #30
pmrphil
The crank will "bend" towards the crack, making contact with the bearing, and opening up the gap on the other side of the crank - it won't take long for that gap (read-"oil clearance") to get larger as the bearing wears, letting the crank move further, etc. etc. Gets ugly pretty fast. At least you salvaged it before it got even uglier, and destroyed everything.
Phil Molski
PMR Performance
S/C 1623
