Liked 8 Times in 3 Posts
Whats the best way to get rid of crankcase pressure with out a pan evac system for a small block stocker??
Liked 66 Times in 31 Posts
Go get you an electric air injection pump off a toyota or gm and build a scavenge tank with a breather. Cheap and easy and fairly effective.
Liked 33 Times in 16 Posts
My low buck solution and legal...
Rich Taylor I/SA - 321 |
The better the engine is sealed up the less Blowby you will have which equals less Crankcase Pressure you will have. If the engine is a wet sump you can measure the Blowby with a good Blowby meter. Low leak down readings do not equal low Blowby.anything over 2cfm is too much.
Liked 971 Times in 308 Posts
Just a simple path for pressure to escape.
Liked 7 Times in 6 Posts
If you have the valve cover connected to the fuel pump block off I don't think you're doing anything. They see the same pressure. I use manifold vacuum through the base of the carb and run a vacuum gauge to measure pan vacuum. It's not great but I do pull about 5 inches at the starting line. That's with both crank seals in the correct way.
#10 | |
Btw, the above images do not show that a breather is used on the passenger side cover. No breather/sealed on the driver side. ![]()
Rich Taylor I/SA - 321 Last edited by HandOverFist; 05-27-2016 at 03:43 PM. Reason: add image |
