There is some talk of using a Dwyer gauge
. What model number is the one you use? I looked on the website but did not know what I was looking for. Thanks.
old 1608 stock racer |
Liked 759 Times in 139 Posts
Henry, a Dwyer Model # RMC-121 is a good choice.
10" tall and a 1 to 10 CFM flow rate. Its around $100. |
Thanks Kevin. Boy oh boy the more I read these posts the more I don't know.
Liked 205 Times in 93 Posts
and what is the purpose of this tester? henry it comes with old age.
Liked 1,892 Times in 423 Posts
To measure blow by on the dyno.
Alan Roehrich 212A G/S |
Can it be used in car off dyno?
That isn't really practical, if it is even possible. It has to be mounted perfectly vertical, and it uses a steel ball to measure flow, so you'd have various G forces acting on it, preventing it from working correctly. Its pretty much a dyno only device. There are some "blow by" or "crankcase pressure" sensors on the market, but they're not cheap.
Liked 783 Times in 195 Posts
Has anyone used any of the electronic gauges that are on the market?
#9 | |
Liked 251 Times in 125 Posts
Is a Dwyer gauge the same as a manometer? I made one years ago for use in testing outdoor power equipment engines.
Maybe it's not precise enough in this case, but here's one similar to the one I made: http://www.obairlann.net/reaper/moto...manometer.html |
