Old 10-12-2016, 03:16 PM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: 69 Camaro Weight
Racing seats can save quite a bit. Lithium battery will save at least 40 lbs on the nose of a stocker.
Mike Pearson 2485 SS
Old 10-14-2016, 01:30 AM   #12
Jim Hawkins
Liked 115 Times in 35 Posts
Originally Posted by jimmyparker View Post
You may not need to get all the way to 50-50, most cars that I have worked on do well with 52% or so on the front.
The '67 six cylinder sub frames were sought after at one time as they were supposedly 20lbs light than the V-8 frame, I never weighed them to verify. They are easily identified due to not having the large holes on the inside near the bumper brackets.
I have 2 67's and one has the large holes in the subframe and one does not. The early car does not have them and they are both original V8 cars. I was told this was done midway in the 67 production for bumper bracket access.
Jim Hawkins is offline   Reply With Quote
Old 10-14-2016, 05:28 PM   #13
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
The '67 subframe legend was started to cover up some chemically milled parts. If the aura of "unique" parts is attached to some identifying factor, people tend to not look at other possibilities. Hence, the '67 6 cylinder subframes, the 520 "T" heads, etc.
Old 10-14-2016, 06:23 PM   #14
J&S Racing
Liked 327 Times in 87 Posts
Is there anybody still chemical milling parts??
Old 10-14-2016, 06:35 PM   #15
James Perrone
Liked 1,865 Times in 435 Posts
Once you have changed out brakes battery and other bolt in components you need to search in every where in the car and remove any little thing . A pound here and there adds up not easy but I can get my nova to the Fsa minimum 200 lb driver. Every little bit counts.
james perrone 1290 STK
Old 02-07-2017, 03:49 PM   #16
boxmotorsports
Liked 58 Times in 23 Posts
I know this is an old post . As James mentioned , its surprising what things weigh... I had Moroso chrome valve covers and the fancy steel hold downs, the covers alone where over 9 pounds each .
boxmotorsports is offline   Reply With Quote
Old 02-07-2017, 04:37 PM   #17
Painter
Liked 162 Times in 45 Posts
James, I need a little ballast to E weght with a 295 motor with my 225 but in the seat. If people cant get their car to minimum they havnt worked and cleaned hard enough.
Painter is offline   Reply With Quote
Old 02-07-2017, 09:24 PM   #18
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Originally Posted by Camarob859 View Post
Have a G/SA 69 Camaro need help losing weight off the nose while staying "legal". Currently car weighs 3255 my minimum weight is 3250 the problem is my weight is 54.76% on the nose, to make it 50/50 id have to add 310 lbs to the trunk!!!!
You don't need to ad 310, you need to move 75-100 to get where you want, maybe even less if its in the right spots
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
