Old 12-19-2016, 02:06 PM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Brake system stuff
Need advice on planning the brake system on a e-body stocker. I have strange discs front and back. Planning on using a 2 step with an adjustable pressure switch. Question are is a line loc and adjustable proportioning valve a must ? And does the pressure switch go on the front or rear circuit ?
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 12-19-2016, 06:57 PM   #2
Liked 10,837 Times in 2,252 Posts
Default Re: Brake system stuff
Pressure switch is on the front on mine without a p valve. Hope this helps.
Old 12-20-2016, 10:01 AM   #3
GallopinGhost
Thanks Larry. Ok, no stock Prop valve, just a distribution block.
Brian Carpenter
Stock 1358
Old 12-20-2016, 12:39 PM   #4
rod butcher
Liked 132 Times in 27 Posts
Same as Larry's with pressure switch between master cylinder and line lock.
rod butcher is offline   Reply With Quote
Old 12-20-2016, 12:51 PM   #5
Coleydog
Liked 53 Times in 38 Posts
Brian, what pressure switch are you talking about? Mike
Old 12-20-2016, 02:57 PM   #6
GallopinGhost
Mike Delahanty had posted a link in an earlier thread, I have it bookmarked on another computer.
Brian Carpenter
Stock 1358
Old 12-21-2016, 12:11 PM   #7
Eman
Liked 133 Times in 76 Posts
I use a Hurst Line Lock and my pressure switch screws right into an extra port on the LL.
Old 12-22-2016, 11:19 AM   #8
GallopinGhost
Eman, sounds simple enough. I think I'll do that. Not really decided on an adjustable prop. valve. If I have no valve, I should have 50/50 brake bias. If that doesn't work well enough, I can always add one to put more bias on the rear wheels.
Brian Carpenter
Stock 1358
