Liked 21 Times in 13 Posts
Need advice on planning the brake system on a e-body stocker. I have strange discs front and back. Planning on using a 2 step with an adjustable pressure switch. Question are is a line loc and adjustable proportioning valve a must ? And does the pressure switch go on the front or rear circuit ?
Brian Carpenter Stock 1358 |
Liked 10,813 Times in 2,247 Posts
Pressure switch is on the front on mine without a p valve. Hope this helps.
Thanks Larry. Ok, no stock Prop valve, just a distribution block.
Liked 132 Times in 27 Posts
Same as Larry's with pressure switch between master cylinder and line lock.
Liked 53 Times in 38 Posts
Brian, what pressure switch are you talking about? Mike
Mike Delahanty had posted a link in an earlier thread, I have it bookmarked on another computer.
Liked 133 Times in 76 Posts
I use a Hurst Line Lock and my pressure switch screws right into an extra port on the LL.
Eman, sounds simple enough. I think I'll do that. Not really decided on an adjustable prop. valve. If I have no valve, I should have 50/50 brake bias. If that doesn't work well enough, I can always add one to put more bias on the rear wheels.
