Old 04-07-2017, 03:53 AM   #1
David Lee
Liked 346 Times in 126 Posts
Default Package tray
If a fuel cell is in the trunk, are we required to seal the package tray with a steel or aluminum cover?
Old 04-07-2017, 08:31 AM   #2
FSA1673
Liked 12 Times in 6 Posts
Default Re: Package tray
Yes, as well as behind the rear seat
FSA1673 is offline   Reply With Quote
Old 04-07-2017, 09:11 PM   #3
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
IIRC, the choices are .028 steel or .040 Aluminum.
2894 STK
Old 04-07-2017, 10:16 PM   #4
David Lee
Thanks off to the local steel supplier I go, is it the same thickness to cover holes in the firewall?
Old 04-08-2017, 02:59 AM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The book specifies .024 steel or .032 aluminum to cover the hole left from removing the heater. Specs aren't given for all the smaller holes in the firewall but I used scrap aluminum and fireproof header wrap for the open grommet holes and black RTV for the pinholes.The RTV was suggested by the local tech.
Disclaimer: I don't race National events.
Dale Shearon
68 Mustang 6394
Old 04-08-2017, 08:14 AM   #6
Painter
Liked 162 Times in 45 Posts
I have found that one inch boiler plate works real well for covering the packsge tray and rear seat areas. A little difficult to get into position but i feel that it gives an extra margin of safety between the driver and fuel cell.
Painter is offline   Reply With Quote
Old 04-08-2017, 09:09 AM   #7
Liked 1,909 Times in 427 Posts
Originally Posted by painter View Post
i have found that one inch boiler plate works real well for covering the packsge tray and rear seat areas. A little difficult to get into position but i feel that it gives an extra margin of safety between the driver and fuel cell.
:d
Old 04-08-2017, 10:11 AM   #8
Hacksaw
Liked 312 Times in 175 Posts
Me thinks that's disguised ballast.
Old 04-08-2017, 10:21 AM   #9
MR DERBY CITY
Liked 8,139 Times in 1,536 Posts
That is exactly what I tell the racers that have me make CUSTOM 50 lb. package trays for their camaros and novas ....they then utter some nonsense about how they love to have weight up that high in their car....I then remind them that when they lock up the brakes at the finish line, turn the car sideways, this 50 lb. package tray could possibly decapitate them....Their final answer.....that's how you drive the stripe...
MR DERBY CITY is online now   Reply With Quote
Old 04-08-2017, 12:11 PM   #10
Coleydog
Liked 53 Times in 38 Posts
Wow, if you stay on here long enough you're bound to learn all these tricks. I was thinkng about putting the stock tank back in to get around having to do this, but not now.I guess that's the last thing to do After I weight the car.
PS. I'm hoping its light enough to use that trick.
