Liked 23 Times in 13 Posts
Is this a dead soldier ??
Found this crack on lower right corner of #7 from water jacket across the deck into a head bolt hole. My immediate reaction is scrap... Any thoughts on this? Thanks, Gary |
Liked 557 Times in 217 Posts
No.....
A crack extending into the cylinder would be bad. The head bolt hole is already open to the water jacket on a stock block so the only issue is thinking about the crack getting worse or some movement that caused a head gasket to leak or fail. I can never recall seeing one like that...... It could be repaired using the stitch weld process and an insert in the head bolt hole.....I'd probably use a stud in that hole instead of a bolt...... It is basically a matter of cost vs how valuable or irreplaceable something is....and what is the intended use of that block....
#3 | |
Liked 1,983 Times in 597 Posts
Mike Pearson 2485 SS |
Liked 239 Times in 114 Posts
Welding up there at the top of the bore ? What would that do as far as bore distortion ?
Liked 719 Times in 220 Posts
Does that crack go all the way through the deck?It might be possible to groove it, stitch weld it, then resurface the block. Wall distortion shouldn't be a problem unless an inordinate amount of heat gets applied to the block, but recheck the cylinder for roundness afterward .
I'm 99 % certain it is completely through the deck. Threads are damaged in the hole already so it needs an insert. I am a little nervous that an insert may force the crack open once loaded.
It's just a street engine 427 11:1 SRP stock crank and rods so not fancy but not looking to build a steamer either. Thanks for the input everyone ! Gary |
Liked 30 Times in 17 Posts
Gary,
If you want to spend the extra money the Loc n Stitch inserts http://castingrepair.locknstitch.com...sh-through-fft would be nice but in all reality a Timesert would probably be fine for a street engine. I don't think you would have to worry about decking it. With the timesert a bolt should work just as good as a stud.
Bill Koustenis |
