Old 06-12-2017, 09:17 AM   #1
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
Default Block deck crack
Is this a dead soldier ??
Found this crack on lower right corner of #7 from water jacket across the deck into a head bolt hole.
My immediate reaction is scrap... Any thoughts on this?
Thanks, Gary
Name:	427 Block.JPG
L78 Nova is offline   Reply With Quote
Old 06-12-2017, 11:36 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Block deck crack
No.....
A crack extending into the cylinder would be bad.
The head bolt hole is already open to the water jacket on a stock block so the only issue is thinking about the crack getting worse or some movement that caused a head gasket to leak or fail.
I can never recall seeing one like that......
It could be repaired using the stitch weld process and an insert in the head bolt hole.....I'd probably use a stud in that hole instead of a bolt......
It is basically a matter of cost vs how valuable or irreplaceable something is....and what is the intended use of that block....
Rich Biebel
S/C 1479
Stock 147R
Old 06-12-2017, 11:56 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,966 Times in 595 Posts
Originally Posted by Rich Biebel View Post
No.....
I agree. Use a stud in that position.
Mike Pearson 2485 SS
Old 06-12-2017, 06:38 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Welding up there at the top of the bore ? What would that do as far as bore distortion ?
Old 06-12-2017, 06:46 PM   #5
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Block deck crack
Does that crack go all the way through the deck?It might be possible to groove it, stitch weld it, then resurface the block. Wall distortion shouldn't be a problem unless an inordinate amount of heat gets applied to the block, but recheck the cylinder for roundness afterward .
Old 06-12-2017, 09:42 PM   #6
L78 Nova
L78 Nova's Avatar
I'm 99 % certain it is completely through the deck. Threads are damaged in the hole already so it needs an insert. I am a little nervous that an insert may force the crack open once loaded.
It's just a street engine 427 11:1 SRP stock crank and rods so not fancy but not looking to build a steamer either.
Thanks for the input everyone !
Gary
Old 06-12-2017, 10:02 PM   #7
BillK
Liked 30 Times in 17 Posts
Gary,
If you want to spend the extra money the Loc n Stitch inserts
http://castingrepair.locknstitch.com...sh-through-fft
would be nice but in all reality a Timesert would probably be fine for a street engine. I don't think you would have to worry about decking it. With the timesert a bolt should work just as good as a stud.
Bill Koustenis
BillK is offline   Reply With Quote
