Old 11-24-2017, 10:03 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default How to disable Turbo 400 kick down?
On my street driven 69 Chevelle with a 496 ( plenty of power ) I don't want the kick down functioning.
I've already disconnected the kick down solenoid , now I apparently still have "modulated" kick down function.
How can I completely disable the kick down?
Thanks in advance.
Old 11-24-2017, 10:22 PM   #2
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: How to disable Turbo 400 kick down?
Thanks in advance.
You could put a full Manual valve body in it
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 11-24-2017, 10:53 PM   #3
joespanova
Is that the ONLY way to disable it? C'mon , there's gotta be another way.
Old 11-24-2017, 11:42 PM   #4
Ed Wright
Ed Wright's Avatar
Why don't you call a local transmission shop?
Ed Wright 4156 SS/JA
Old 11-24-2017, 11:58 PM   #5
Did you try screwing the modulator adjustment in?
Might have to screw it out, then re-work the governor, now that I think about it.
Not your normal S/SS question, Joe.
Old 11-25-2017, 12:11 AM   #6
joespanova
Because.....its Fri. night , its 10:30 and I want to know , now.
The modulator and "kick down" function isn't so clear to me.....I wanted to delay the 1-2 shift so I increased modulator tension , to solve that.
Now how all this relates to eliminating downshift / kick down......I have no clue.
Old 11-25-2017, 12:26 AM   #7
Well , you're in luck then, Joe because I'm here in Az.
Find the 3-2 valve and block it so it won't move. 2-3 should work fine with absence of gov. and mod. pressure for downshifts after slowing.
Old 11-25-2017, 10:35 AM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Like Mark said just block the 3-2 downshift valve.
Small valve at bottom right of photo .
I use a piece of 3/16" brake tubing ,about7/8" long , file it for a final fit .
Been doing this for years ,works great .
Old 11-25-2017, 04:36 PM   #9
joespanova
Thanks guys.......in this view is the mod present? Where is the tubing?
Old 11-25-2017, 05:12 PM   #10
Tom Goldman
Sorry ,been off line for a while ,Damn Work ! No it is not shown in the picture . You substitute it in place of the spring .
When I get home , I have a good picture of it I'll post.
