#21 |
I think that you would probably slow down more than .5. You can't use the big 2V on your combo and the L index is tough.
#22 |
Liked 208 Times in 35 Posts
At 3418lbs your car would be n/sa with a 13 flat index. 3418 -170 for driver devided by 224 hp =14.5 n/sa Rick
Rick Winchester Stk 3277 |
#23 |
Liked 586 Times in 162 Posts
Sorry, my mistake on the classification. Yes 3418 is 52 lbs less than my current minimum and .85 less than my current index so about a .90 difference, right?
#24 | |
Liked 684 Times in 289 Posts
Only 1 L car (-.617) at 1-7 LODRS @ E-town. A few N`s, and at least one of them used to be in L. See Billy`s post above. Mike A114 Last edited by Mike Jones; 12-18-2017 at 11:43 AM. |
#25 |
Liked 53 Times in 38 Posts
#26 |
Rich said his car weighed 3418. One would assume that's with the driver weight added. So, the 170 needs to be removed to find the natural factor for the car. Then you would adjust to the lightest possible weight for that class. Then add the the driver weight for the total weight with the 2 bbl .combo.
#27 |
Liked 404 Times in 158 Posts
I’m still wrapping my head around the 350cfm for the 305 2bbl and 500cfm for the 350 2bbl.
302 is 287cfm and 351 is 356cfm. Only wish Ford had 350cfm on the 302. |
#28 | |
69-70 350s use "really big" 2bbl, about 400 CFM. All other 350s use "big" 2bbl at about 350 CFM. FFFFord put 350 CFM carb on 82 manual trans Mustang GTs only.
