Old 02-21-2018, 11:59 PM   #11
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Thoughts on accepted aftermarket heads for 350?
Originally Posted by 5389stk View Post
Question who actually submitted all these heads to NHRA or did NHRA pick them out. All these heads cc way to big to be used in stock.
Can't answer that. The AFR 1399 aluminum head is NHRA approved for SS, but it ships with 1.9 and 1.6 valves installed. Larger than the Ford heads it's approved to replace. You would have to knock the valve size down to pass a SS tear down. I wasted a couple of grand on believing the Approved list, so be careful.
AFR `1399
58cc
valves 1.9/1.6
I runner 165cc
E runner 68cc
c8oe f J code 302/230
49.5cc
valves 1.783/1.457
I runner 130cc
E runner 49cc
Got iron heads now.
Dale Shearon
68 Mustang 6394
Old 02-22-2018, 11:58 AM   #12
Bobby Lundholm
Liked 127 Times in 49 Posts
Originally Posted by Todd Hoven View Post
Great thing about aluminum. You can weld it up, reprofile it, and cover it up. It will look like new and you probably pick up 30 hp at least. You have to do
something to keep up with the Mopars.
Any modifications to the runners are illegal, so if they match up to the stock numbers NHRA will know they are modified.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 02-22-2018, 12:08 PM   #13
Mark Ugrich
Liked 71 Times in 38 Posts
So if I’m understanding this correctly , you must run the aluminum/ replacement heads in either stock or super stock using the runners as they come from the manufacturer. The exception being replacing the valves and seats with the correct OEM sizes?
Old 02-22-2018, 12:10 PM   #14
Bobby Lundholm
That's what I'm understanding. The air flow is going to be restricted by the intake regardless, so with the larger head runners i don't think it'll help that much.
Old 02-22-2018, 12:45 PM   #15
FireSale
FireSale's Avatar
That's what I was told regarding my AFRs. Smaller valves would degrade the heads performance. The shop that does work for Hancock and Lane advised against that route.
Dale Shearon
68 Mustang 6394
Old 02-22-2018, 12:59 PM   #16
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Thoughts on accepted aftermarket heads for 350?
I know of at least one stocker 428 CJ intake manifold that is 10 lbs lighter in wt. than any others. No grinding on the outside either !
Old 02-22-2018, 01:02 PM   #17
FireSale
FireSale's Avatar
Anyone notice that the approved Dart head is iron?
Dart catalogue
Iron EAGLE s/s 23° 165cc (55-86 Std. Intake Face)
72cc Chambers – 1.940”/1.500” Valves
10021070 Bare Head
NHRA Accepted Stock/Super Stock Cylinder Head Volumes Updated June 14, 2017 Highlighted items designate recently added since last revision
Head # 10021070 Dart
Intake CC's Max 172
Exhaust CC's Max 65
Same As Stock 80-92 305; Same chamber CC's, valve sizes as head replacing intake and exhaust
Dale Shearon
68 Mustang 6394
Old 02-22-2018, 01:07 PM   #18
Bobby Lundholm
Dart catalogue
10021070 Bare Head
It's listed in the Accepted Products release pg 42 (2017) under that part number.
Yes that one is on the top of our list to work with.
Old 02-22-2018, 01:10 PM   #19
Bobby Lundholm
I still don't think you make the intakes big enough to really let the heads breathe. What's the standard CC of the stock Chevy intakes compared to a 185 cc head runner?
Old 02-22-2018, 01:34 PM   #20
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
#1 Greg Hill; The Edlebrock heads are 185 cc’s on the intake runner. Who approves this stuff?
Follow the money............
# 2 Todd Hoven "Great thing about aluminum. You can weld it up, reprofile it, and cover it up. It will look like new and you probably pick up 30 hp at least. "
Think about it, Read between the lines.. this also applies to Aluminum Intakes...
# 3 "I was looking at them and the Dart look to be the best without going to the aluminum heads"
Don't count on it , if this deal stays at +5hp for replacement heads, the Iron will be way disadvantaged, esp if the combo has an Alum Intake. refer to comment #2
Obviously, no one who has a clue of stock eliminator made the decision to include these alum heads replacing factory cast iron. I'm not a chevy guy but now as I see it in the guide the 350 has choices of 4 replacement heads plus the original. As mentioned in another thread here on CR that potentially creates 5 sub combos of the same engine. In the future will we need 5 hp factors for the same engine? Yea, and this goes for all the Makes also, whether it's a Mopar Ford or GM.
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
