Old 07-03-2018, 02:08 PM   #31
Bobby DiDomenico
Liked 101 Times in 52 Posts
Default Re: Wheel Studs
Put big studs in and forget about it!
Problem with that is stock wheels no longer can be mounted.
Old 07-03-2018, 10:53 PM   #32
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Sometimes!
I can still mount my stock SS wheels with the extended Wheel Studs.
As for new studs.
Mine would not stay at 85# after installing them.
Re-Torqued them to 110# until the Torque Wrench indicated they were tight.
Today taking previous advice mounted new M/T Front Runners and Slicks.
Torqued rears to 100# and fronts to #85#.
Old 07-04-2018, 06:31 AM   #33
Liked 10,849 Times in 2,254 Posts
My bad, I thought it was a problem on a race car.
Old 07-04-2018, 10:05 AM   #34
Dan Fahey
Dan Fahey's Avatar
You correct! It was the 95 Impala SS.
Just can mount the Stock SS wheels and tires even with Long Studs to store the car over the winter.
Old 07-04-2018, 11:34 AM   #35
Dave Gantz
Liked 251 Times in 125 Posts
Maybe Larry is talking about bigger diameter studs.
Old 07-04-2018, 04:27 PM   #36
Dan Fahey
Dan Fahey's Avatar
Yup missed that..
To do that would have to Machine the Wheels for Larger Studs.
Going to a stronger higher strength Stud should be enough!
Old 07-04-2018, 06:35 PM   #37
Ed Wright
Ed Wright's Avatar
Yup missed that..
Which would be the logical thing to do.
Ed Wright 4156 SS/JA
Old 07-04-2018, 09:33 PM   #38
Dan Fahey
Dan Fahey's Avatar
I have Moser Wheel Studs!
That good enough?
D
Old 07-05-2018, 05:30 AM   #39
james schaechter
I really think something is not right with the wheel vs the lug nut perhaps. So what if the shank was too long and bottoming on the stud ever so slightly? The result would be a wheel that was not being clamped as tightly as you think. It could allow the wheel to work on the studs and eventually break them. Maybe this came up before. You could face the shank on the lug nuts to shorten them up a touch if they were close.
James Schaechter 3163 STK
Old 07-05-2018, 06:49 AM   #40
Bobby DiDomenico
Had to do that with some lugs that bottomed out on the hub and brake drum Jim. Measured the wheel thickness and a shop with a coolant cutting wheel shortened them for me. Big diameter studs were not an option because they would have limited the wheels we could throw on the car.
Seems something here is preventing the wheel from being clamped tight.
