Old 01-20-2019, 08:48 PM   #21
Stick Racing
Default Re: Penn vs Valvoline test results..Ed Wright
May I ask the part number of the Valvoline oil you refer to?
I have used the VV850 in the past but they no longer offer it.
I believe they changed the formulation.
Do you use an additive with the oil?
______________________________________
Andy Stone A/S 1102 SS/C 1112
Stick Racing is offline   Reply With Quote
Old 01-21-2019, 12:26 AM   #22
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
The oil I used is straight 30 racing oil. It used to be commonly called VV223 but the Valvoline part number is 822401. Scroll down a little to find Valvoline's conventional oil part numbers, https://www.valvoline.com/our-produc...vr1-racing-oil
I don't use any oil additives.
Ron Gusack is offline   Reply With Quote
Old 01-21-2019, 07:34 AM   #23
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
don't use either.
Been running Mobil 1 Synthetic 10w-30 in my race engines for nearly 3 decades.
This past season switched to Lucas Synthetic. Have a case of Maxima Synthetic that I will run this season.
Old 01-21-2019, 09:18 AM   #24
Alan Nyhus
Liked 799 Times in 236 Posts
Originally Posted by Ron Gusack View Post
This might be true Alan, but I don't see the same amount in the pan after switching to Brad Penn, which has no moly. If I convince myself that the VR1 has better wear numbers, I'll gladly live with some goop in the pan.
Finished the 2018 season using Red Line 5-20 synthetic race oil. There was very, very little additive separation when I pulled the pan. What you see in a cold oil pan...full of cold oil...isn't an indicator of what's happening when the oil is hot and flowing.
The oil deal is a bigger issue for Stockers that have to use a flat tappet camshaft combined with high spring pressures and aggressive lobe profiles. For those not running under that set of rule constraints, there are dozens of oils that will work well.
Excessive additive precipitation is something to consider when choosing an oil filter. Those dots can be connected accordingly. -Al
"That'll never work....."
Old 01-21-2019, 09:44 AM   #25
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Penn vs Valvoline test results..Ed Wright
The question that I can't seem to get a decent answer to is why so many racers use multi weight oil instead of straight weight.
It's my understanding that multi-viscosity oils get circulated faster on start-up when it's cold, which helps protect sooner and reduce wear. I also read some time ago that multi-viscosity oils make more HP, but I don't recall why. It might be that drag engine oil don't usually reach "normal" operating temperatures, if I understand viscosity numbers correctly. (i.e.: 10w-30 - 10w=cold, 30=hot.
Valvoline says that straight weight oils are usually recommended for smaller and older engines.
5th question down:
https://www.valvoline.com/about-us/f...-viscosity-faq
LOCOMOTION Racing
Old 01-21-2019, 11:32 AM   #26
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Originally Posted by Greg Barsamian View Post
Looking for Opinions / Experiences on the differences between using Valvoline VR 10w-30 Synthetic-Blend vs Valvoline VR 10w-30 "Full Synthetic" motor oil?
Specifically with respect to ring wear?
I had really good luck with the full synthetic Valvoline racing oil. Cant seem to find it anymore at the local parts stores.
Mike Pearson 2485 SS
Old 01-21-2019, 12:41 PM   #27
Randall Klein
Liked 316 Times in 67 Posts
I've been really happy with JR-1
You may want to look at Reher-Morrision tech tips on oil and filters, oit of 100 tips they are toward the end (95 & up as I recall) Filter tip very interesting
One thing they told me was to try Bad *** oil, I believe the originator of the early good Royal Purple.
FWIW
Old 01-21-2019, 12:53 PM   #28
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I don't change it often. I cut the filter open after each race. Guess it gets a new quart in the new filter each race. New oil about mid season. Clean oil, clean filters, I don't see the point of more often changes. May be why I don't see a pan full of crap like some discribe.
Thanks Ed!
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 01-21-2019, 04:13 PM   #29
SSDiv6
Liked 1,597 Times in 583 Posts
There is a racing oil brand that has been recommended to me by Nick Ferri.
It's manufactured in the USA by HPL Superior Lubricants.
Nick shared with me that it is the oil he has been using for some time; it makes power and protects the engine. I believe Bo Butner is also using HPL Racing Oils too.
https://www.hploil.com/
Old 01-23-2019, 11:15 PM   #30
Ed Wright
Ed Wright's Avatar
For a tough heads up, mine is just a few hundredths quicker on Royal Purple "race 9", which is, IIRC, zero-10wt? Pours like water.
A friend in the lab at the Sunoco refinery here locally tested some oils for myself & a couple of racer/friends. The highest load before gaulding the ball on the load tester was 10W30 Valvoline VR1. I had used Penzoil for years, since they furnished my oil for a few years ago. When the free oil ended, I felt like I owed it to them to start buying it. Tested well also. The VR1 handled more load than anything. RP was very close. They tested what I could find. Pennzoil tested well too. VR1 tested best.
I am not claiming to know everything about this. Only what friends tested for us.
Your results may vary.
Ed Wright 4156 SS/JA
