#11 |
Liked 880 Times in 311 Posts
The way I read the new Head rules is that any aftermarket head is legal in SS Modified. Doesn't need to be factory part number any more.
some CFE splayed valve in SS/AS or AJ 18 degree in SS/BS??
Adger Smith (Former SS) |
#12 |
Liked 116 Times in 27 Posts
Could you forward where you read this? Interested, Thanks.
Richard Preiser 1613 FGT/I 1510 C/SA 161 F/DA |
#13 | |
The aftermarket cylinder head needs to be approved by NHRA and added to the list of NHRA accepted products. No billet heads allowed although there are rumors of some billet heads in use that have been made to look like a casting. It took me close to a year to get an Edelbrock cylinder head approved. |
#14 |
Liked 237 Times in 126 Posts
Be careful down there in the Modified and Modified Stock classes of SS. Read and stick to current rules.
SuperStock Modified "V-8 splayed valve permitted in AM and BM, canted or inline in CM through FM, and any valve configuration in GM with V-6 engine. All heads must be NHRA-accepted, two valves per cylinder. Aftermarket aluminum cylinder heads permitted (no billet)." Where it matters: SS/CM Aluminum canted heads allowed with NHRA stamp. SuperStock Modified Stock "V-8 splayed valve permitted in AS, canted or inline in BS, inline only in CS, and any valve configuration in DS. All heads must be NHRA-accepted, two valves per cylinder, except in classes DS, ES, FS, and GS, four valves per cylinder permitted. Aftermarket aluminum cylinder heads permitted (no billet) except in CS." Where it matters: SS/CS Inline iron heads only. Watch your Modifieds.....
#15 |
In the recent past, cylinder heads used in NHRA Super Stock Modified class had to have an OE casting number. However current rules state that aftermarket aluminum heads may be used in this class. But it also states that the heads must be on the "NHRA approved head" list. Make sure that the heads you chose to use are in this NHRA "list" and keep a hard copy of this list in your files. Yes, it is true, NHRA has been known to change their minds on this sort of things in the past. If your heads happen to get dropped from the list in the future, you should be "grandfathered in" with the list of the approved heads in your possession.
#16 |
Liked 34 Times in 7 Posts
Here is current list of the legal aftermarket heads allowed in the SS/Mod classes.
So whats on here or having a genuine factory part number is whats legal. Good luck, have fun!
VENICE PERNO SS/CS 3041 NHRA SUPERSTOCK Last edited by Ven302; 02-15-2019 at 06:09 PM. Reason: forgot the .PNG |
#17 |
Sorry for any confusion, I missed the Approved, lingo!!
WoW, that 14500000C Dart head is a 9 deg head.. AJ 18 head won't hang with that
Adger Smith (Former SS) Last edited by Adger Smith; 02-17-2019 at 04:02 AM. Reason: add |
#18 | |
Ford boys use the N351 Sportsman head with a 10 degree valve angle. It's not on the list because it's a Ford part number M-6049. n351. It's on the SS/CS record holder.
#19 |
Liked 314 Times in 177 Posts
That Ford head is iron and nobody would use that in any other class than SS/CS.
#20 |
Liked 7 Times in 5 Posts
