#31 | |
Liked 372 Times in 130 Posts
...and if converting a 2008-2012 Challenger body was easy, to look like a 2019, then maybe that could create a more cost reasonable combo. I am not familiar with how hard it would be to convert the bodies on those Challengers
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#32 | |
Liked 286 Times in 146 Posts
Essentially the hood, dash, and the front and rear fascias. Most of the FS/XX Challengers last year, started off as earlier models. Probably best to start with one of the unused original 2009 Drag Pak's that were only supposed to be sold to racers and be raced, but ended up sitting in collections losing value, since most of the hard work is already done. |
#33 | |
So it sounds like converting a body to a 2019 style is a bolt on affair ? The dash will most likely be taken out any ways to remove un-necessary stuff and/or install the cage.
#34 | |
Liked 627 Times in 156 Posts
Pete Lanciers PAL Automotive Racing Stock 7801 |
#35 |
Liked 53 Times in 38 Posts
392 junk yard engines (with accessories) around here start at $5-7000, early Challengers around $12,000. 2012 SRT 392 with miles around $20-30,000. That engine in stock form has some get up and go, headers, cam, "stocker work" maybe 600 or more hp potential, mine ran 12.50 105 spinning the first 100 ft, all stock, 308 gear, HEAVY. There was nothing like this back in the heyday 60s.
#36 |
I would like Jeff Teuton to share some insight on the robustness of the 392 engine as regards especially the bottom end and the main caps. As I understand, the main caps are powered metal.
#37 |
Liked 694 Times in 206 Posts
A 15-19 Challenger flood car is the way to start. No need to convert any front or rear trim and panels. A complete crate engine is the easy but more expensive way to start. You can order the block, heads and crank from Dodge. Many parts to buy to get one of these together. I'll let you know in the end.
#38 | |
#39 |
The hood is a 15-18 Hellcat hood. They are $800 or so new depending on the deal you can find plus paint. Last year there many Houston flood cars available at a cheap price. After selling off motor/trans/rear end/wheels tires/interior the basic shell was free. But, it’s like picking up a piece of wood and thinking you have a house for free! At least you have a rust free body to start with.
#40 | |
Liked 904 Times in 237 Posts
Don Kennedy 7701 SS |
