Old 11-13-2019, 12:13 PM   #11
Jack McCarthy
Liked 477 Times in 117 Posts
Default Re: VP and Sunoco
Careful transporting fuel ... I believe over 15 gallons (inc fuel cell) requires DOT placard and DOT rules ...
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 11-13-2019, 12:19 PM   #12
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
What is the most common Sunoco and VP fuel carried at tracks?
I do not see Sunoco 260 GTX much at all.
Dan
Old 11-13-2019, 04:16 PM   #13
cmracing
Liked 62 Times in 29 Posts
Not sure if this varies by state.
I picked up two 55 gallon drums of fuel a few months ago for some friends. I was told this was totally legal, AND, I could have taken two more drum of Alky to go along with that race fuel since they have different numbers on the tag indicating what was in the drum. I was told there is a weight limit, not a gallon limit.
Also was told I could legally transport up to 900 pounds of radioactive materials without a permit...........
But like most things, when the State and Federal Government gets involved, things get messed-up! Some states require a CDL for our tow rigs, others don't. Would be nice to have common laws across the country, but that will never happen.
cmracing is offline   Reply With Quote
Old 11-15-2019, 12:26 PM   #14
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
My toter holds 100 gallons of fuel so I doubt they would care about 15 gallons of gasoline. I do haul it in the VP 5 gallon steel containers. I also have a 25 gallon gas tank for the generator in the trailer, Sometimes I carry a couple of 5 gallon containers of Non Ethanol gas for the golf cart and the small suitcase generator.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 11-15-2019, 12:59 PM   #15
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Everything I have ever found says that placarding is not required if the total weight of the fuel is under 440 lbs and packaged in containers less than 8 gallons.
S/ST 51
S/C 53
Old 11-15-2019, 05:03 PM   #16
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Dan
I ordered this fuel locally and it took over 2 months to show up. VP C10 is easier to get at least here.
Dave Noll, EF/S ,?/SA 6526
Old 11-15-2019, 07:39 PM   #17
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
CFR49 states that hazardous materials placards applies to shipping companies and drivers hauling commerce. It does not apply to private individuals.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 11-16-2019, 01:02 PM   #18
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Dan
Here you go Dan , pick it up or have it shipped,, cheap enough !!
https://petroleumservicecompany.com/...4-gallon-drum/
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 11-17-2019, 12:30 PM   #19
ken robinson
Liked 224 Times in 87 Posts
Originally Posted by Dissident View Post
Fuel check is using a dielectric constant meter that has been zeroed against a standard such as Cyclohexane or Indolene. Typically Cyclohexane. IF it passes, ok....IF not, yer outa there regardless of what fuel you claim.That method of NHRA fuel check has been in place for many decades.
Now I heard that if you used some 1,4 dioxane.......well, that is another story. LOL
Regards,
HB2
Dissident
1,4 dioxane acts like an ether. It will pass the fuel check ?
Old 11-17-2019, 10:37 PM   #20
Dan Fahey
Dan Fahey's Avatar
Why do fuels change one day as legal!
Later does not pass?
What fuel blends tend to fail the most?
