Old 12-25-2019, 04:27 PM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default Re: th 350 ultra bell
Originally Posted by richie 2 View Post
the trans must come apart to install?
I have done several powerglides with out disassembly.
Mike Pearson 2485 SS
Old 12-26-2019, 10:02 AM   #12
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Unless the Bell is specific to a aftermarket Case, (Reid, etc.) they will bolt on with your existing pump bolts. The tricky part is the Sanitary cutting of your existing stock Bell
SC 707Y
Dano is offline   Reply With Quote
Old 12-27-2019, 06:05 AM   #13
richie 2
Liked 205 Times in 93 Posts
so no trans shield required if ultra/bell used ?...didn't realize that...
Old 12-27-2019, 08:57 AM   #14
Dano
Dano's Avatar
I think if required, you still need a blanket around main case.
SC 707Y
Old 12-27-2019, 11:24 AM   #15
pmrphil
Liked 348 Times in 152 Posts
The ultrabell only replaces the flexplate shield, not the trans shield/blanket.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 12-27-2019, 11:44 AM   #16
Dano
Dano's Avatar
A good quality trans case blanket is less expensive than taking apart the trans, shipping, cert expense and shipping it back, putting back together, (if someone else needs to do this). Just saying...…...
SC 707Y
Old 12-27-2019, 11:54 AM   #17
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
I have a TH350 Ultrabell on the shelf from an old combination. BOP ears have been cut off for firewall clearance so it only fits SBC now.
Kept cracking 350 cases in the bell housing until I went this route.
$250
dragracer77@hotmail.com
Chad
Chad E532 is offline   Reply With Quote
Old 12-28-2019, 10:37 AM   #18
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Originally Posted by Eman View Post
They are nice and strong but they are also thicker and bigger. That might be a factor in a car with a stock floorpan transmission tunnel. I have a 3rd gen F body and the drivers side is very tight to the bell.
Thus, my request to allow removable tunnels in stock that was shot down. It's a shame they don't understand that people want to make a car safe but not such a P.I.T.A. to work. on.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-28-2019, 07:47 PM   #19
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
and don't forget those dangerous glass windows because we would all be safer with Lexan..
Why don't we just leave Stock alone for a while rather than trying to " Fix it"
Bob Mulry 7516 STK
A & M Motorsports
Old 12-29-2019, 11:23 AM   #20
Terry Cain
Terry Cain's Avatar
You're probably right. Lexan would make it safer. I'll let you fight that battle. Just don't understand NHRA requires same safety equipment in a stocker VS Super Stocker but getting it to fit in a non-massaged tunnel is impossible on some cars. Not aware of Super Stockers running Lexan. ??
Terry Cain ???? STK
