Old 12-29-2019, 10:34 PM   #121
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Welp, looks like 2020 will be the final year for us!
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 12-29-2019, 11:28 PM   #122
bykr
Liked 167 Times in 81 Posts
Correct me if I'm wrong but if you angle mill the head at an extreme angle thereby reducing the port volume and NHRA only measures the head port volume aren't these "spacers" allowing larger cylinder head port volumes? It's not really about adapting different intakes but using the "spacer" to raise cylinder head port volume as the head isn't measured with the spacer installed. I guess the port entry can be raised also. Seems like a reasonable rule change to me. Although I feel for those affected, anytime you push the rules you put yourself in a position to have the rules get tightened, not in you favor whether it's been accepted before or not.
bykr is offline   Reply With Quote
Old 12-30-2019, 12:39 AM   #123
SSDiv6
Liked 1,604 Times in 583 Posts
The volumes are measured without the adapters.
Old 12-30-2019, 12:42 AM   #124
Thanks , Joe
(123 posts later ;-) )
Old 12-30-2019, 02:10 AM   #125
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
I wonder if exhaust adaptors will be illegal too? I mean, the angle should be checked on the exhaust side, if the intake rule gets reinstated!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 12-30-2019, 02:14 AM   #126
bykr
That's my point. If you mill the head at a severe angle won't the cc's of the cylinder head runner be reduced? You can then open the runner up in other areas to bring the head back spec. cc's. The whole point of doing it.
Old 12-30-2019, 09:28 AM   #127
Bobby DiDomenico
Liked 101 Times in 52 Posts
That's what I thought. Besides a better intake you're gaining CC's to work with and possibly changing the entry angle somewhat.
Old 12-30-2019, 05:07 PM   #128
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
I don't understand the problem if porting, polishing, welding and epoxying is already permitted?
From rule book SS heads -
Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA-accepted. Cylinder-head casting must also be on NHRA runner volume list as published on NHRARacer.com. Porting, polishing, welding, epoxying, and acid-porting permitted.
Mike Gray is online now   Reply With Quote
Old 12-30-2019, 06:33 PM   #129
bykr
Look at it this way.If a cylinder head had 200 cc port volume and you mill away 20 cc's with this angle milling. You now have a head with 180cc's that you can open up to the 200cc spec. which then could perform like a non angle milled 220cc head. Why else would they do this?
Old 12-30-2019, 11:20 PM   #130
Sean Cour
Sean Cour's Avatar
look at it this way.if a cylinder head had 200 cc port volume and you mill away 20 cc's with this angle milling. You now have a head with 180cc's that you can open up to the 200cc spec. Which then could perform like a non angle milled 220cc head. Why else would they do this?
Sean Cour
T6066 ladle
