Old 03-01-2020, 09:03 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Rod bearings
Just went to order a set of rod bearings, have always used Clevite 77 trimetal with good results. I was informed no longer available, now only available in the A suffix aluminum material. I know this is the way most of the OEM's have gone, anyone had any problems going with the aluminum material?
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 03-01-2020, 10:04 PM   #2
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Rod bearings
Jim,
I switched to King bearings some years ago and they have held up great...showed much less wear then my old Clevites.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 03-01-2020, 11:05 PM   #3
1299
Liked 54 Times in 12 Posts
Ran into a problem with clivet a few years back and switch to kings. Change nothing other the bering company and solved all my problems
1299 is offline   Reply With Quote
Old 03-02-2020, 09:45 AM   #4
richie 2
Liked 205 Times in 93 Posts
M77 u can purchase them coated now...
Old 03-02-2020, 10:15 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I've been using King Black Max bearings for several years with great results.
Besides good wear,they are more consistent in size when setting oil clearance .
Old 03-02-2020, 10:29 AM   #6
Tom Goldman
Jim , is this for the 258?
I used King CR648SI bearings in Eric's engine.
They are the bi metal type , King does not have the Tri metal available for the 258.
No problems with wear on them .
Old 03-02-2020, 01:20 PM   #7
pmrphil
Liked 348 Times in 152 Posts
Part number and undersize? I've got more stuff on the shelf than I should have.
Phil Molski
PMR Performance
S/C 1623
Old 03-03-2020, 10:05 PM   #8
jmantle
CB-906P for 6
Old 03-04-2020, 10:05 AM   #9
pmrphil
Originally Posted by jmantle View Post
CB-906P for 6
Nope, sorry. Lots of 960's, but no 906. Phil
Phil Molski
PMR Performance
S/C 1623
