Old 07-31-2020, 03:39 PM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Av gas
Does any one want to tell what the dual rating on AV gas is about? like 115/145 ??
Choices:
A. Heat value
B. Resistance to engine icing
C. Octane
D. Volatility rating
Adger Smith (Former SS)
Old 07-31-2020, 03:58 PM   #12
John Kissel
Liked 230 Times in 94 Posts
Default Re: Av gas
Wow, weren't you lucky to get to use that stuff.I got to use 100LL for years,in Florida but if you try to by it where i now am, you get treated like a crimminal.Now, I love all of the stuff I buy from VP. but I will notice little bits of trash in the screen of the funnels I use, the funnels are the ones alcohol guys use with a very fine mesh screen in it. One is for my car, and the other for my small engines. This is with 110 or SEF. Just wonderin'. John Kissel K242
John Kissel is offline   Reply With Quote
Old 07-31-2020, 04:00 PM   #13
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Av gas
Choices:
A. Heat value
C. Octane
The Lean Mixture rating is 100 octane (15 octane higher than the comparable 85 MON for unleaded Mogas) but Avgas also has a Rich Mixture rating of 130 which allows higher supercharger boost pressures to be used without detonation occurring.
I thought the high number was heat value, but I cheated and went to google
Old 07-31-2020, 09:16 PM   #14
Shake & Bake
Liked 37 Times in 33 Posts
Smile Re: Av gas
When I use to do a lot of street racing back in the day I would buy AV gas from the local airport.(Told them I was using it at the dragstrip). They told me it was 105 octane. I would then mix Super 104 +" Real Lead" with it to up the power a little more.
Adding one quart of "Real Lead" additive in 20 gallons of AV gas would take it up another 5-7 numbers.
Seriously, 1 gram of metallic lead per gallon of gas equals a level of protection no substitute can match....Not to mention it stops knocks, pings, run-on, overheating and piston damage caused by fuel that's too low in octane.
Shake & Bake is offline   Reply With Quote
Old 08-01-2020, 08:37 PM   #15
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Av gas
115/145 was 115 octane lean & 145 Auto Rich or Military Power...
We also had a a J-34 jet engine under each wing that used 115/145 for fuel and part of our pre-flight was to reach inside the tailpipe to break of the stalactites of lead from the fuel.
Flew in P-2V Neptunes .......2 turning & 2 burning
Bob Mulry 7516 STK
A & M Motorsports
Old 08-02-2020, 12:35 PM   #16
Jeff Kempton
Jeff Kempton's Avatar
Liked 67 Times in 31 Posts
Default Re: Av gas
As soon as I started reading the second paragraph I thought "This guy flew in Neptunes!" lol
I didn't, but I'm familiar with them. We have one on display at an aviation museum that I'm involved with, and the Royal Canadian Air Force also flew them for a few years.
Jeff Kempton is offline   Reply With Quote
Old 08-02-2020, 04:28 PM   #17
Adger Smith
Default Re: Av gas
We have some winners...Basic.. rich lean octane..
The only thing that hasn't been mentioned is the chemical enhancement that AV gas has to help keep Carb ice from forming. It doesn't cool like racing gas when it evaporates/vaporizes. So it puts some heat in the induction system that race gas doesn't.
Personal Experience:
My 172 with the 300 Continental "6" engine runs better on a 50/50 mix of 100LL Av Gas and non ethanol 87 octane pump gas. Simply because the engine was designed for 85 octane gas. I have an STC to fly with automotive gas, but the mix is better.
BTY: Jeff and Bob I have an old friend that has been working for a company leasing planes to the Govt. for fire suppression. He started off flying a modified Neptune and moved up to a DC-10. Somewhere I have a video of him in the Neptune making a run on a ridge that was on fire... Cool stuff.
Old 08-03-2020, 12:00 AM   #18
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Av gas
A long time ago, while on active duty, we all ran 115/145 Purple AV Gas in everything we drove. The price was right. It was the best smelling fuel that I have ever used. Up on the wing filling tanks, that fuel was so volatile it cast a shadow across the wing...
R-3350 Twin Row Radial Engines - 3350CI = 3850HP
Was that version the compound turbo charged engine..?
I know they were put on Connies that made 3350hp...
Old 08-03-2020, 02:13 PM   #19
Bob Mulry
Bob Mulry's Avatar
Default Re: Av gas
They had 3 PRT's Power Recovery Turbines each rated 150HP that fed the power directly back into the crankshaft using a reduction gear setup.
They grouped 6 of the 18 cylinders together so the exhaust of 6 cylinders powered each of the 3 PRT's.
We even had an R-3350 with a Chevrolet Bow-Tie build plate.
Back then my rating was AD(R) 2 with the R standing for Recips.
Punched a lot of holes in a lot of clouds.
Bob Mulry 7516 STK
A & M Motorsports
Old 08-03-2020, 04:27 PM   #20
Dan Fahey
Dan Fahey's Avatar
Default Re: Av gas
Allison experimented with a compound turbo set up.
Got something like 3000 hp.
Never went past that stage.
Most everything they developed in WW2
We are using today.
