Old 03-26-2008, 05:40 PM   #1
SSDiv6
Default GM Dexcool Settlement
It appears that GM has decided to settle the Dexcool class action lawsuit.
http://www.girardgibbs.com/dexcool.html
Old 03-26-2008, 08:02 PM   #2
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
Default Re: GM Dex-cool Settlement
It is about time. I have heard this was coming for a long time. Our family owns 4 repair shops and we have done hundreds of these repairs. The best thing you can do is flush your cooling system and install good old fashion green antifreeze. I was blown away after reading this that they did not include the 5.7 or the 7.4 they suffer from the same problems.
Tommy Gaynor is offline   Reply With Quote
Old 03-27-2008, 12:35 AM   #3
csjta
Default Re: GM Dexcool Settlement
Are they not still using Dexcool in all there vehicles?
csjta is offline   Reply With Quote
Old 03-27-2008, 12:07 PM   #4
Dave Cook
Dave Cook's Avatar
That is funny, I flushed all that green stuff out of my 5.7 truck in '97 and replaced it with Dex-Cool, haven't had to touch it since.
And people wonder why American industry and the economy has gone to s#*t, everyone wants to sue over their own problems, caused by their own negligence.
Dave Cook is offline   Reply With Quote
Old 03-27-2008, 02:59 PM   #5
CPOlesen
Talking Re: GM Dexcool Settlement
193,000 on original DEX-COOL.. Still rollin
CPOlesen is offline   Reply With Quote
Old 03-27-2008, 04:47 PM   #6
SSDiv6
You have the tendency to jump the gun with your comments.
It is not negligence...it is a combination of a bad designed intake gaskets and the intake manifold and the effects of the Dexcool formulation. GM has redesigned the 3.1 and 3.4 intake gaskets several times; the latest redesigned intake gasket was introduced in 2003. Also, the intake manifold was redesigned too; the best intake is the replacement intake made by Delphi, or use the aftermarket intake made by Dorman.
Tommy Gaynor has confirmed this is a problem that has been happening for many years. I have seen cars under 30K with the leaking intake manifolds and gaskets. Also know of people that took their cars to the dealer to have them fixed, paid the average $750.00 ~ $900.00 cost, if the engine could be reapired, and see it repeat again 15k later.
Therefore, the source of the problem was found to be Dexcool.
Check out these other sites and educate yourself:
http://www.dsengine.com/gmgasket/index.html
http://www.zillamotorsports.com/DEX/
Old 03-27-2008, 08:09 PM   #7
Don Whitmore
SSDiv6...do you know the improvements the Delphi and Dorman manifolds have?
I've got a friend with a 3400 and this exact problem, Dexcool in the oil pan...helped him pull the engine last night. He doesn't know there are better parts out there...
Don Whitmore is offline   Reply With Quote
Old 03-27-2008, 09:30 PM   #8
Jamie Greening
I do about 4 to 6 a month at our shop. The main problem is not the Dex-Cool in most cars. The problem is a combo of the intake gasket design (plastic gaskets) and the low torque the intakes torque at. Fel-pro and GM both have a revised intake gaskets for the 3.1, 3.4, 4.3, and 5.7 engines. They are a metal design gasket with bonded rubber around the water outlets and ports. We have had excellent luck with these gaskets because they hold the torque setting so much better. We have one set on our 4.3 stocker that have been reused 4 times. The Dorman intake for the 3.8 is a great intake for replacement.
Jamie Greening is offline   Reply With Quote
Old 03-27-2008, 10:03 PM   #9
SSDiv6
The Dorman intake is made of better material and also they reinforced the weak areas.
Dorman has an intake kits and reseal kits for GM and Ford products:
https://www.dormanproducts.com/docum...dSellSheet.pdf
Old 03-28-2008, 11:09 AM   #10
Dave Cook
Dave Cook's Avatar
I've done plenty of the leaking intake gaskets, just never blamed it on the Dex-Cool, I blame it on the poor gaskets and some of the poorly designed and plastic intakes.
It isn't the coolant.
I put Dex-Cool in everything I own when I do the flush and fill, because my stuff sits a lot.
It's hard to drive 9 vehicles every day.
