Old 03-10-2021, 01:31 AM   #1
Garry Dearn
Default Tuesday H.P.
Here it is gang-22 H.P for 2009-2013 Dodge Challengers. From 300-322 H.P.-Stock Automatic Only.
Garry Dearn is offline   Reply With Quote
Old 03-10-2021, 01:51 AM   #2
Paul Wong
Liked 419 Times in 85 Posts
Default Re: Tuesday H.P.
Without a tear down as well.
Paul Wong is offline   Reply With Quote
Old 03-10-2021, 02:02 AM   #3
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Ok Paul I’ll bite, why not... did the culprit bolt before a request could be made? Was he there for eliminations or just took the trophy and ran?
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 03-10-2021, 08:59 AM   #4
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: Tuesday H.P.
The engine was still sealed from a teardown last fall ..... Maybe someone can highlight us as to why he was removed from the ladder...?
Jim Bailey is offline   Reply With Quote
Old 03-10-2021, 09:33 AM   #5
Jim Bailey
Additionally, FYI , he was torn down (again) at Gainesville.
Old 03-10-2021, 09:48 AM   #6
Jim Bailey
Also, he wasn't removed from the ladder, he was a no show. ( probably because his engine was completely apart ...)
Old 03-10-2021, 11:08 AM   #7
GTS340
Liked 1,361 Times in 416 Posts
I take it you were there Jim watching these tear downs. Hard to believe a stock bore production engine can seal up that well to make near 600hp. If not more! He goes .325 green and catches a second under competitor by the 660' is amazing all in its own. He has plenty left after coasting from the 1100' mark for all the F,G and still H cars now even at 322hp. Might need a better reaction though. That's what happens when you show that kinda performance. You bring extra gaskets.
Paul Haszlauer
Old 03-10-2021, 11:42 AM   #8
jamie2370
Liked 239 Times in 90 Posts
Paul Haszlauer
Looks like stock bore is 3.920 and MAX bore is 4.000. Thats .080 over and Diamond makes an approved piston for it, not to mention it is a +18 cc dome piston. Seems pretty easy other than you need a couple dead bodies in the trunk to make weight lol Also he only went 60 to 80 under last year. I think the engine really likes the bigger, lighter, better ring package, pistons.....just saying
jamie2370 is offline   Reply With Quote
Old 03-10-2021, 12:01 PM   #9
GTS340
I have said this before. I was the one who got the piston approved which happened the last few days of Jan 2021. The only thing available before that time (The record set in Nov 2020) had to be a OEM piston. Chrysler doesn't make an oversized piston. You can buy an oversized piston from other vendors but that isn't approved. That is why I worked with Diamond and NHRA to get it excepted. It took a while. Is it stock bore, Left and right offset piston with a press on pin like stock OEM? If so it is good to go or does he claim stock piston and it isn't?
Old 03-10-2021, 01:02 PM   #10
Kenney Kelley
Liked 72 Times in 36 Posts
If the car can run that fast it might be in the wrong class to start with. I think the car with the extra 22HP. only needs to add 92 Lbs. to move to G/SA or remove 69 Lbs. and move up to F/SA. This is from the 3620 Lbs. at 300 HP. that was the Min. weight at the 2021 Baby Gators for that car combination in H/SA. Kenney Kelley
Kenney Kelley is offline   Reply With Quote
