Old 04-04-2021, 02:56 PM   #1
RJ Sledge
Liked 288 Times in 90 Posts
Default Flat tapper lifter Stock Eliminator?
Best choice for Stock Elim FE Ford build..
I have used Schubeck and Trend tool steel in the past but it’s been a while.
Thanks
RJ
RJ Sledge is offline   Reply With Quote
Old 04-04-2021, 09:19 PM   #2
mnmaxwedge
Liked 172 Times in 53 Posts
Default Re: Flat tapper lifter Stock Eliminator?
Trend or PPP tool steel lifters. Need DLC coating if using on a steel core cam.
mnmaxwedge is offline   Reply With Quote
Old 04-05-2021, 08:02 AM   #3
Liked 10,822 Times in 2,250 Posts
^^^^^^^^^^^What he said RJ.
Old 04-05-2021, 08:43 AM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
R.J., on a cast cam, I've had excellent luck with the Trend tool steel lifters. They offer a reduced diameter pushrod cup oil hole option to control upstairs oil, if desired. They can also be recrowned and repolished several times for a very reasonable fee. Good products, great service and very timely delivery and turn around time.
Non coated on a cast cam (nitrided or not).
For a 8620 or steel billet cam, the PPPC brand DLC coated are great.
Hope this helps. -Al
"That'll never work....."
Old 04-05-2021, 11:33 AM   #5
RJ Sledge
Appreciate the info, this would be on a cast cam.
I had a bad experience the last time I put an FE stocker motor together, I was using a cast cam and Trend Tool steel hyd short travel lifters and was breaking in motor on my test stand, thought I had broken motor in correctly.
I noticed above normal “metal” trash during filter inspections and decided to look at internals. Found lifters going away and several lobes in bad shape.
After talking to cam manufacture (independent) and Trend I believe camshaft was not heat treated correctly. But it bothers me not nothing the reason for failure.
Both parties naturally denied being at fault, but lean towards improper heat treatment on cam. Still trying to learn.
Again, I appreciate your info.
Anybody notice any performance increase running solid lifter vs short travel hyd lifter??
Do the big cam co’s still offer optional camshaft treatments/coatings on cast cams and is it worthwhile??
Thanks
RJ
Old 04-05-2021, 12:09 PM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Thanks
RJ
Did you reduce spring pressure during break in?
Glenn Briglio is online now   Reply With Quote
Old 04-05-2021, 12:31 PM   #7
SSDiv6
Liked 1,604 Times in 583 Posts
Thanks
RJ
RJ,
It is not the first time the cam company you are using has experienced issues with the heat treatment of their camshafts. Heard the same issues from others. Also, as Glenn stated, the break in spring pressure has to be lower than the spring pressure you use for racing. I would pay the additional cost and use a steel core in lieu of a cast core. Yes, there is a difference in power between the solid lifters and the limited travel lifters and it shows in the Spintron.
Old 04-05-2021, 09:45 PM   #8
GTX JOHN
We saw absolutely NO improvement on changing to solids
from low travel Hyd. Lifters in my Stockers on the Track.
I still use Smith/Schubeck time bombs in my stockers.
MY son runs the Trend solids in his Demon 340 Stocker.
I am looking for more to buy.
John Irving
741 Stock
741 Super Stock
Old 04-05-2021, 11:36 PM   #9
RJ Sledge
On my Stocker I run 200/400 for spring pressure and have used the Trend tool steel lifters without breaking in with old oem springs and had no issue before.
Now I had a bad experience and don’t need another lesson ...
I ordered set of lifters from PPP today to use on a cast cam so I will install some lite springs and change to my beehives after run in stand session.
I never had an issue with schubecks/smith style lifters, but still hear horror stories of bad experiences.
Appreciate all the info
Thanks
RJ
Old 04-06-2021, 05:29 PM   #10
Jim Hanig
Liked 99 Times in 49 Posts
Smile Re: Flat tapper lifter Stock Eliminator?
Thanks
RJ
RJ i think that the bigger lifter helps the Smiths live i have talk with a couple of ford guys say they never had a problem.
