Old 06-29-2021, 08:58 AM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Lt1 rear gear?
What is preferred rear gear in a lt1 camaro. What is rpm difference between 4.88 and 5.14. How much would mph change. Not looking for answers from a calculation but from some people with experience with lt1 combo.
Kdw1403 is offline   Reply With Quote
Old 06-29-2021, 10:43 AM   #2
GUMP
Liked 2,354 Times in 554 Posts
Default Re: Lt1 rear gear?
What class?
Old 06-29-2021, 11:09 AM   #3
Kdw1403
B,c/sa
Old 06-29-2021, 11:18 AM   #4
GUMP
I would run the 4.88. I never saw any gains from running more gear with an LT1. I also favor a 94" tire.
Old 06-29-2021, 11:50 AM   #5
KRatcliff
Liked 534 Times in 143 Posts
I have always favored running as much gear as your engine can RPM. It is physics to me for moving a heavy stationary object and accelerating it through the 1/4 mile with the tongue hanging out at the end.
A 5.14 with a 94" rollout Hoosier or a 4.88 with a 92.5" Hoosier would be where I would lean. They almost work out the same. Our LT1's carry more weight than in the past and I think enough gear is key.
I was running a 5.00 for a long time and would bounce between the 92.5" and 94" depending on the air. I don't run an automatic anymore so I went to a different gear. I do have a new in the box Richmond 5.00 that I need to sell.
KRatcliff is offline   Reply With Quote
Old 06-29-2021, 01:45 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I made the gear swap from a 4.56 to a 4.88 and basically saw no ET difference.....
RPM went up 200-300
I was running A/FIA at the time and weighed around 3050lbs
Engine made it's fastest runs shifting 1-2 under 7000 and 2-3 at 7000
10.50's 124-125 in good air Not killer fast but not terrible.....that was 15 years ago !!
Rich Biebel
S/C 1479
Stock 147R
Old 06-29-2021, 02:13 PM   #7
GUMP
Unhappy Re: Lt1 rear gear?
We also ran a 4.56 in the IHRA days in A/FIA and Top Stock.
Old 06-29-2021, 02:56 PM   #8
BrayJo
Liked 6 Times in 5 Posts
Are you running a Metric trans?
If so, with the 4:88 and 94 rollout what RPM are you through the lights?
BrayJo is offline   Reply With Quote
Old 06-29-2021, 05:37 PM   #9
KRatcliff
Originally Posted by KRatcliff View Post
....I do have a new in the box Richmond 5.00 that I need to sell.
I didn't actually list these yet, but they sold about 15 mins after I posted to a buddy in Houston. Thanks for all the interest.
Old 06-29-2021, 05:39 PM   #10
Rich Biebel
I drove the car in 2011 at 2 races and by then it weighed 3200 in B/SA
Probably had the same 4.88's in it and a better fuel map and maybe a little better engine
Went 10.50's at 124-125 in real good air at Maple Grove....
Had E-shift in it then and Hoosiers.....
I ran 3066 M/T's and felt like they were faster than the Hoosiers.....
I did try moving the RPM up back when I owned the car but it did not run faster....
Big improvements in various engine parts and mods since then maybe make that not true anymore...
A few cars around that are pretty fast considering the weight that got lumped on them since I owned one....
One of my all time favorite cars I ever owned and raced....
Rich Biebel
S/C 1479
Stock 147R
