Old 12-22-2021, 05:21 PM   #1
tolaas
Default Motor mounts
Hi, can i use the big block motor mounts and frame mounts for a small block on a -67 camaro?
Thank`s , Torbjorn
tolaas is offline   Reply With Quote
Old 12-23-2021, 09:32 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Motor mounts
I doubt you will find many people who can tell the difference by sight. FYI, the big block mounts move the engine forward a bit, so take that in to consideration.
Old 12-23-2021, 11:06 AM   #3
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Re: Motor mounts
Thank`s , Torbjorn
Big block mounts also move the engine toward the passenger side. Transmission crossmember is different too (trans mount offset to the passenger side). Z bar is different (accounts for the offset). There’s more little stuff as well but all of the above is one big reason why header fit can become an issue in these cars. Some bbc headers are built for stock bbc locations. Some are not.
Wayne Scraba is offline   Reply With Quote
Old 12-23-2021, 05:11 PM   #4
tolaas
Mr. Sutherland, have you seen this car before? Look in the attachment.
Name:	camaro 3 S.jpg
Old 12-25-2021, 09:21 AM   #5
Dwight Southerland
Absolutely. I shipped an engine to Sven way back in the '90s! Spent many hours on the phone with him. I always intended to go visit him.
Old 12-25-2021, 01:09 PM   #6
tolaas
Hi, nice to hear that. I bought the car from a norwegian who bought the car from Anders, Svens son. It`s a car with very fresh body but there must be a bilion people who has drilled holes in the firewall and floor, i have welded more fifty of them!! I gone have a 350 and 200 transmission so i got som new engine mounts from OER, a disaster!! they doesn`t fits at all.
How much does it moves the engine forward with BBC mounts?
Thank`s Torbjorn Laas
Old 12-25-2021, 02:25 PM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Is it the frame mounts that move the engine or the engine mounts?
I see moroso offers mounts but look like matching pairs. Same as energy suspension.
chris ok is offline   Reply With Quote
Old 12-25-2021, 07:43 PM   #8
L.Fite
Liked 497 Times in 243 Posts
Frame mounts relocate engine. Going from memory about 3/4 or 1 inch.
It's not much but enough to make a difference in fitting headers.
'67-'68 are different from '69, so the motor mounts are different for '69 also.
Don't know why they changed but the width is different.
Also 302 engine frame mount is shorter also...
So there is that...
L.Fite is offline   Reply With Quote
Old 12-26-2021, 09:16 AM   #9
Dwight Southerland
My '67 car was a 327 originally. When I built it as a 302, no problems with fitting. Later I decided to convert to a big block, so I went to Chevrolet and purchased new 396 frame mounts. I ordered headers from Jack Davis and when I tried to install them, they would not clear the crossmember. Jack said the headers were designed to use small block frame mounts "because everybody does that to move the engine back". So the small block mounts wen back into the car.
There is a difference.
Old 12-26-2021, 10:53 AM   #10
Wayne Scraba
This article might help...😀
https://www.onallcylinders.com/2021/...sion-position/
