Old 12-22-2021, 01:16 PM   #21
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: New AHFS
2020 was an abbreviated schedule, lower car count, and didn't make mineshaft. 2019 ,18, 17 would have made it easily ,@ .95 under.
Without flat out conditions, I doubt you'll see it at Indy.
#65 qualified at .855 under Indy 2020.
Old 12-22-2021, 01:17 PM   #22
Albert Lee
Liked 258 Times in 49 Posts
Like NHRA, there are very few heads up runs but there is a curve ball: you can't go more than a tenth faster than the quicker car qualified in a heads up.
Love vs tolerate comes to mind.
Albert Lee is offline   Reply With Quote
Old 12-22-2021, 02:24 PM   #23
jmantle
Liked 172 Times in 81 Posts
Personally I think mineshaft should be weather related before it is placed into effect. Low temp, low humidity and high Barometer should be the trigger along with stiff tail wind.[/QUOTE]
So if the DA is less than the actual elevation of the track it's mineshaft?
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 12-22-2021, 02:38 PM   #24
Ray Gottry
Ray Gottry's Avatar
Liked 68 Times in 24 Posts
Duane you have a PM.
Ray Gottry is offline   Reply With Quote
Old 12-22-2021, 03:29 PM   #25
Yes.Let me clarify.
I should have spelled out what I meant.
2020 would not have met the new - .95 requirement, even though it was still a flat out deal. ;-)
Old 12-22-2021, 05:22 PM   #26
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
So you work on your performance based class to have your car capable of running 1+ seconds under, you have a heads up and the #1 qualifier was .89 under. You ice, thin oil and all the other stops and run 1.10 all out, maybe because you had a worse light. What happens then? You lose? Or maybe you both run more than a .10 under?
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 12-22-2021, 06:11 PM   #27
jmcarter
jmcarter's Avatar
Liked 3,199 Times in 977 Posts
Think Al needs to clarify, never heard of this “curve ball”, in fact it sounds more like a screw ball or knuckle ball.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-22-2021, 06:48 PM   #28
GUMP
Liked 2,354 Times in 554 Posts
The NMCA gives points for qualifying position. They WANT our cars to go fast!
The .10 rule allows for ice, etc. (If you didn't do that during qualifying)
Daren Poole-Adams
NHRA Stock/SS 2007
Old 12-22-2021, 07:49 PM   #29
Albert Lee
Clarifying "curve ball" heads up.
Car A qualifies 105 under, Car B qualifies 75 under. If heads up, both boards read 115 under and normal breakout rules apply.
Just the messenger!
AC
Old 12-22-2021, 08:14 PM   #30
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Cool Re: New AHFS
I'm a little bit confused; how can you break out on a heads up run?
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
