Old 01-08-2022, 12:15 PM   #91
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Explain to me again, please
Originally Posted by Grey Ghost View Post
Roller lifters have been OEM in many motors starting in the 1990s. There is probably 1/3+- of the current stockers using them now. Many if not all were originally hydraulic. It would be naive to believe cam grinders are not taking advantage of having a roller lifter for those motors. Other advantages of these combos are programmable ecu's and efi.
I don't believe rollers for everyone are another step towards SS. Having them available to all would take that advantage away from the "modern" combos.
Just looked at entrees for Gators. Best I can count and tell, 31 flat tappet motors, the rest are rollers.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-08-2022, 01:17 PM   #92
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Let me say I don't have stocker. But from someone looking in from the outside.Stop adding band aids and put the stock back into stock racing. Since NHRA will not do its job of teching the cars / engines. Maybe you can get NHRA to let you self police yourselves and have a say in what rules you want.
Stan
Old 01-08-2022, 01:32 PM   #93
GUMP
Liked 2,354 Times in 554 Posts
There has always been a protest rule....
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 01-08-2022, 01:36 PM   #94
SSDiv6
Liked 1,604 Times in 583 Posts
Originally Posted by Terry Cain View Post
AND on a stocker we're (correct me if I'm thinking wrong) not allowed to change that and it does come into play on a BBC.
200 lbs might work on a small valve motor.
The basics for setting up the valve geometry is simple.
Use a pushrod length checker, the rockers you are plan to use in your engine and a solid lifter at Zero lash.
Use Dykem or a marker at apply it to the tip of the valve. Rotate the engine several times, remove the rocker arm and check the contact pattern of the rocker tip against the tip of the valve.
The contact pattern on the tip of the valve should be centered and as narrow as possible. Adjust the pushrod length checker until you achieve the optimum contact pattern, measure the length of the checker and order the appropriate pushrod length.
Old 01-08-2022, 01:44 PM   #95
Barry Polley
Guest
Posts: n/a
Where’s Bubski when you need him?
Most of our parts are offshore now and yes you c a n get a quality part offshore. Don’t like it but it is a fact.
Putting a year rule in would end S T O C K
No offense Stan but we all know where (self police) would get us. Kinda like cutting the police budgets.
Old 01-08-2022, 02:04 PM   #96
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
The contact pattern is rarely centered but getting it as narrow as you can is good.
Old 01-08-2022, 02:14 PM   #97
SBillinson
Liked 183 Times in 48 Posts
There's nothing in the rulebook that states you can't do lifter correction.
Before someone says that there's nothing in the rulebook that says you can, here are some things that are not in the rulebook that people are doing.
Using $1500 millimeter ring packs with spacers, some with lateral gas ports which are prohibited on pistons. Blending the valve job from the bottom cut of the seat to the top of the valve guide boss. Roller cam bearings. Bull-nosed cranks. Using clean PVC to pull vacuum in the crankcase. Oil shedding coatings. Trick ignition systems. Etc.
Here are a couple of things that people have been doing for a long time that are prohibited in the rule book. Porting heads and intakes and covering up. Modifying carburetors especially Holley's.
Let's not forget $6000 transmissions with aluminum everything and dozens of gear ratios. Trick rear ends with ceramic bearings, profiled ring gears and impact coatings.
Lifter correction is more in line with engine blueprinting than all of the above. I'm pretty sure people have been doing it, probably for a long time, especially on aftermarket blocks.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 01-08-2022, 02:22 PM   #98
BBC OEM Hydraulic
Just a thought then. If you don't want to wait 6 mos. and spend $2100, why not put the last hyd. cam and lifters back in, for now? At least you could race your car.
Old 01-08-2022, 02:26 PM   #99
SBillinson
That's a great point.
Nobody is forcing anyone to buy a billet crank or tool steel lifters or do any other modification.
SS/BS 1921
Old 01-08-2022, 03:17 PM   #100
SSDiv6
You are correct. The reason why the rocker arm of choice for SBC and BBC are the Jesel approved rocker arms. For other makes, I use Harland Sharp since they have dedicated rocker arms for specific engine makes in lieu of a "one fits all" rocker arm like other companies do.
