Old 02-01-2022, 09:27 AM   #11
Rsmith38
Liked 28 Times in 15 Posts
Default Re: C11 and C12 in fuel check
Failed twice at Epping Nationals. Had run out of C-10 and used track sunoco. Brought 5 Gal can and it tested OK. Problem was fuel cell Foam. Removed it and no further problems. If you have foam in the cell it will hold the previous bad fuel!! No foam for ME!!!
Rsmith38 is offline   Reply With Quote
Old 02-01-2022, 09:53 AM   #12
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Just a clarification. It must be a safety risk to run a fuel cell without foam.
You just can not get all the "failed" gas out of the foam when you dump the "bad" fuel so the "good" fuel is mixed with the "bad" fuel and you might fail again.
We finished that race without foam and replaced it for the next race.
Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 02-01-2022, 12:13 PM   #13
garyc
Liked 51 Times in 30 Posts
First time running stock this year, what happens when you fail fuel check and when do they do it?
garyc is offline   Reply With Quote
Old 02-01-2022, 12:59 PM   #14
jamie2370
Liked 239 Times in 90 Posts
Fuel cell foam is not required. It is designed to slow down sloshing when braking or turning. Also you may find that "plastic" fuel cells will also cause a fuel to fail.
jamie2370 is offline   Reply With Quote
Old 02-01-2022, 02:11 PM   #15
Hacksaw
Liked 312 Times in 175 Posts
They usually check first or second qualifier and any heads up race. Also could be random times. If you fail in qualifying, your run gets thrown out. If you fail in eliminations, you get bounced.
Old 02-15-2022, 09:01 PM   #16
jmantle
Liked 172 Times in 81 Posts
Originally Posted by Rory McNeil View Post
Don`t know how much heat, humidity, etc effects the sample, but I have had C12 from a 2 year old drum pass no problem, yet several years ago, I bought 10 gallons of C12 from the VP truck at Seattle, and the following weekend, at fuel check at Sonoma, the guy doing the testing, said that the fuel I had bought one week prior, was borderline. I have to think the drums of fuel taken to the National Events, should be pretty fresh. Go figure.
Every time I had my fuel checked (C11) at Sonoma they told me it was borderline but never had that issue at Vegas. I'm sure it was the same tech guys, maybe it was the altitude.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
