Old 04-02-2022, 05:20 PM   #1
ss chief
Liked 48 Times in 13 Posts
Default Shifting on rpm or time
In SS can you shift on rpm or time?
ss chief is offline   Reply With Quote
Old 04-03-2022, 08:45 PM   #2
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default Re: Shifting on rpm or time
What ever turns your crank on that one!��*
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 04-05-2022, 10:34 AM   #3
SS734
Liked 4 Times in 3 Posts
I thought only RPM was allowed?
Using "the transbrake release" to start a timed event seems defiant of current rules in Super Stock?
SS734 is offline   Reply With Quote
Old 04-05-2022, 12:02 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Pretty sure the only things allowed to be hooked to the trans brake circuit is the brake solenoid and the rev limiter. They even frown on the replay tach connected to the brake circuit
Mike Pearson 2485 SS
Old 04-05-2022, 12:59 PM   #5
Question Re: Shifting on rpm or time
You can shift by time if you use your wristwatch..
Old 04-05-2022, 01:50 PM   #6
GTX JOHN
We always use RPM on our SS cars.
We do not wear watches.
John Irving
741 Stock
741 Super Stock
Old 04-05-2022, 03:47 PM   #7
Mike Mans
Liked 299 Times in 48 Posts
You can do it with either if you use an MSD PowerGrid. They have a built in timer that can be used for any feature you would like. You can turn on a brake light at 5 seconds into the run if you so choose
Mike Mans is offline   Reply With Quote
Old 04-05-2022, 04:13 PM   #8
SS734
Hmmm, I don't see any options for using MSD power grid in the rule book? Is this located somewhere else?
Old 04-05-2022, 05:22 PM   #9
Maverick
Liked 36 Times in 26 Posts
Need to look for accepted products list, probably on nhraracer.com
Old 04-05-2022, 10:09 PM   #10
Mike Mans
On the accepted list, page 79 it's MSD 7730 (this is the PN for PowerGrid).
https://www.nhraracer.com/Files/Tech...edProducts.pdf
