Old 05-06-2022, 12:47 PM   #11
Danny Ashley
Liked 110 Times in 29 Posts
Default Re: 2 step low rpm
Robert: In some cases, it may be necessary to tighten the air valve tension slightly when going from foot braking to 2-stepping. It depends on the tension you have as a starting point. It could be that it's tight enough and you won't have to do anything. I would try it as is and if you notice any "fluttering", then tighten it a little. Hope this helps.
Danny Ashley is offline   Reply With Quote
Old 05-08-2022, 10:06 PM   #12
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Just buy an 8735 MSD Launch Control….
It takes 2 chips 1 for burn out and 1 for high RPM, but the Launch Control has dials to set the leave RPM
Easy, Peasy
Bob Mulry 7516 STK
A & M Motorsports
