Old 09-20-2022, 10:48 PM   #61
Default Re: Russ linke
One last thing - there were three other racers in tear down and not much said about them.Hmmmmm..............
Jack, None of them made the 6 o'clock news...
Old 09-21-2022, 10:59 PM   #62
Kdw1403
Liked 68 Times in 22 Posts
Who is Russ linke”s engine builder?
Kdw1403 is offline   Reply With Quote
Old 09-22-2022, 10:40 AM   #63
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Tbis thread has been beat to death.No use going down this road with more speculation imo...gsa612
Old 09-22-2022, 10:47 AM   #64
HR9121
HR9121's Avatar
Don't see much relevance in that as anyone could change head gaskets after the fact. If there was say an overbore on the block then I would say there might be an issue as far as the engine builder. Like I said before you race the car you are the one responsible for what's in the car.
James Williamson
W200 J/SA. SS/JA
Old 09-22-2022, 12:43 PM   #65
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
This thread has totally gone off topic
Jake Biermann
Old 09-22-2022, 01:02 PM   #66
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
https://www.nhraracer.com/content/ge...651&zoneid=132
Old 09-22-2022, 01:18 PM   #67
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
The racer named in the post title, his DQ, and his equipment is precisely the topic.
S/ST 51
S/C 53
Old 09-22-2022, 02:39 PM   #68
Originally Posted by Tim H View Post
There ya' go ..
Those who were wanting to see more, so sorry.
The precedent is now set.
Happy heads up!
Old 09-22-2022, 04:42 PM   #69
gsa612
gsa612's Avatar
Nowadays you can have the piston at any deck height, as long as you make the min.spec.listed in the NHRA blueprint spec.for that engine.Before you had to have the factory deck which was posted then run a gasket to get the posted min.My motor has a .008 neg.deck,total deck is .030 in the specs.the min.gasket thickness would be .022 to get to .030.Now I can put the piston at zero deck but have to have a min.030 gasket to get to the .030 min.spec.You have to use the gasket thickness to get to the listed min.spec. ...gsa612
Old 09-22-2022, 06:04 PM   #70
John, Good luck on that .030 deck :-)
Th e 78 400 Pontiac is +.004 with .043 gasket.
The PT Felpro was .048 out of the package.It would compress to around .043.
You had to run a + deck back then so we had to shoot for something on the + side, like .001 or .002 to be safe.
Wesley never did like that rule, and eventually it was changed to what we have today.
The LT1 is .015 down , with a .047 gasket.
That means, if you had at a - .013 piston , hypothetically speaking, of course, you'd need a .049 - .050 compressed gasket.
The Felpro gasket spec is .047 to .053, so a word to the wise there.
Cometics are pretty much as ordered, but not cheap.
As much as they cost though, you wouldn't want to toss them around, willy nilly.
You'd probably have a good handle on this.
There..I should be a politician with this one ;-)
