Liked 83 Times in 32 Posts
Why would a stocker need to drain the fuel after a heads up run. #asking for a friend.
I know the answer and it passes fuel check. |
Liked 3,227 Times in 981 Posts
Dry ice
Liked 1,856 Times in 433 Posts
Some people run different fuel in a heads up
Dry ice just makes it cold.
james perrone 1290 STK |
There is an additive that passes I'm sure the ones who know wont say a word,
#5 | |
If you know, and you care enough to post this, spit it out man! LOL
James Schaechter 3163 STK |
What the secret sauce
I’m a cheater and I don’t know
Liked 165 Times in 60 Posts
Interesting question your friend has there Mr Herb jr !!! Bubski also thought it was intriguing and phoned a friend !! Apparently there are fuel additives that the masking agents used to dupe the fuel check will break down rather quickly and may be an issue later on in the day !! Bubski just wondering why they don't put the "fuel check fuel" in the fake radiator overflow like they do in D7 and pull up about a 100 feet away from the scales so a few semis can get weighed and get your fresh sample for tech !! Its good to see someone paying attention !! Cheers !!!
Liked 1,354 Times in 413 Posts
See it is possible to learn something new every day even at 65 yrs old. I'll try not to be first every time down the track to verify here in D7 we cheat on fuel.
As far as changing fuel. I'm too lazy and run C-11 all the time but some run the less expensive till the time to get a little extra is needed. Possibly in the third person mode your invisible too. Paul Haszlauer |
#9 | |
Liked 598 Times in 164 Posts
Us racers police ourselves pretty hard. You can bet you Bubski ash any racer involved in a heads up would call out a competitor that stopped to dump fuel or switch lines. Second tech officials for the uneducated do peak under the hood when giving the sample. Not always but more often than you might think. Plus there has not been a competitor caught doing something like this in decades if ever. |
Liked 354 Times in 120 Posts
More than likely it was C25, also the secret sauce that makes there cars go faster is a mix of time, effort, and money. Congratulations to both racers for having bad *** cars and were not afraid to turn them loose. Truly this is what class racing is all about. Tom
Tom Meyer 5240 SS Stock ??? |
