Old 01-25-2023, 11:18 PM   #1
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default VP C12 Alternative ?
I'm sure this has been covered many times. I have a 327 / 300 super stock engine, flat tops. no crazy compression or anything but it will see some decent rpm. I was gonna run C12 but I will honestly mainly run stick shift races. Whats a good affordable alternative ? Is the Sunoco 112 pretty comparable ? Any back to back tests ?
JCChildress is offline   Reply With Quote
Old 01-26-2023, 12:47 AM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: VP C12 Alternative ?
Sunoco 110 should be plenty. Better yet C-11.
Always test.
Dave Noll, EF/S ,?/SA 6526
Old 01-26-2023, 07:00 AM   #3
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: VP C12 Alternative ?
Always test.
Good morning to all,
As Dave advised always test, every combination requires something different.
VP C-12 will work well , I've found on our lower compression engines that the C-11 was slightly better, but again everyone's combination is different ( even within similar engine family's) Timing , Camshaft , Jetting and other outside factors will have a bearing on the "ultimate" fuel for your engine combination. Good luck and enjoy your accomplishments found during your testing.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 01-26-2023, 11:59 AM   #4
Jody Lang
Liked 92 Times in 29 Posts
Renegade 110 when it first arrived in my area was much cheaper than C12. Haven’t bought any for awhile now. Definitely worth looking into. Cars ran the same.
Jody Lang is offline   Reply With Quote
Old 01-26-2023, 01:13 PM   #5
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I tested C11, C12 and Sunoco Blue the same day. .001 between all three. That was in the wagon. Maybe a different result in a light car.
Bob Bender 144 O/SA
Old 01-26-2023, 10:06 PM   #6
littlemanjoe
Liked 75 Times in 28 Posts
For us C11 is faster but we had to make some timing and jet adjustments over C12.
littlemanjoe is offline   Reply With Quote
