Old 01-31-2023, 12:22 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Mopar perch on housing
To the Mopar group, what angle do you weld the perch (on housing) when using the Calvert setup and mono spring? Same as stock? A-Body car
Old 01-31-2023, 12:49 PM   #2
Default Re: Mopar perch on housing
Why not ask Calvert?
Old 01-31-2023, 01:07 PM   #3
Coleydog
Rather ask Mopar guys
Old 01-31-2023, 02:22 PM   #4
GTX JOHN
We run 1 to no more than 2 degrees down.
If you miss it can be corrected with wedges from
most spring shops.
Try to not get housing real hot.
John Irving
741 Stock
741 Super Stock
Old 01-31-2023, 03:26 PM   #5
Coleydog
Thanks, some said 5 or 3 down, I like 1 or 2 idea
Old 01-31-2023, 10:01 PM   #6
GTX JOHN
With the old SS Springs or Tri City Super Launchers
3 to 4 would be correct but not for the Calverts
John Irving
741 Stock
741 Super Stock
Old 01-31-2023, 10:34 PM   #7
Gmirza
Liked 253 Times in 95 Posts
I switched from SS springs to caltracs and didn’t move the perches. It’s the original housing with the perches in the factory spot. Car hooks all the time. Just check the housing alignment, my car was 3/4” different from one side to the other.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 02-01-2023, 08:45 AM   #8
Liked 10,837 Times in 2,252 Posts
The spring perch can be a real challenge. The housing has to be straight with the body. It needs to be zero toe in or out. Camber has to be zero or the tires won’t be 90* to the track. Everything may be just perfect until you weld on it. Then everything changes. A thick tube housing will still move as in a Dana 60 but not as much as an 8 3/4. The first one I did the axels would not go in without a hammer. The fun part was getting it straight again.
One to two degrees down
Old 02-01-2023, 10:29 AM   #9
pmrphil
Liked 348 Times in 152 Posts
Weld on the opposite side of the tube and it will pull it back. Ugly, but it works. Or, get somebody with a jig to put new ends on it after you weld the perches on.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 02-01-2023, 11:18 AM   #10
Coleydog
All good advice so far, racers know their stuff.
