#21 |
Liked 920 Times in 259 Posts
#22 |
Liked 251 Times in 125 Posts
I've been using an old Imperial, similar to this one: https://www.ebay.com/itm/18551982762...Cclp%3A2047675
I just learned something this past year. I was having a hard time stopping a new double flare from leaking. After googling, I found out if you don't quite finish the second flare, when you tighten the flare nut, it will "finish" itself. I.E. the flare will finish forming as you tighten it against the seat. Presto! After making several flares, including making a new line when it got too short, using this technique, it sealed on the first try. Maybe this is common info, but I thought I'd mention it. |
#23 | |
Liked 93 Times in 52 Posts
Faster classes require steel. I do highly recommend very good support for the rear brake lines. I have had a flare break in the flare nut at the caliper due to vibration. |
#24 |
Liked 44 Times in 14 Posts
I have a flaring kit I got from Inline Tube. It will double flare stainless brake line without annealing. I have done lots of show cars and some race cars with this. Most race cars I do 37 degree with tube nuts and sleeves. I love this tool!! Part # TLF08 and the 37 degree dies are seperate. Stainless lines and some Kugel Komponents line clamps are the bomb!!
#25 | |
Liked 62 Times in 17 Posts
I have the same kit with 45 degree dies. I've only used it on steel lines, but it works great. |
