#31 | |
Liked 80 Times in 29 Posts
#32 |
Liked 2,359 Times in 557 Posts
For someone with so much to say, you sure are out of touch...
Daren Poole-Adams NHRA Stock/SS 2007 |
#33 |
You may be correct.
It's the lack of due diligence that is at the foundation of my character flaws. At the risk of incensing some, I'll ask again. That's an interesting suggestion. What was the reasoning behind it? |
#34 |
Liked 1,948 Times in 589 Posts
The way I read the review process is if there are 2 runs more than 1 second under the index for a particular combo and platform then an automatic review will happen. If the class average is more than .85 under at the time of the review the combo will receive a HP increase based on the fastest run by that combination. If the class average is less than .85 under then index no HP increase happens. So if you made 2 runs faster than one second under this year you will automatically get a review to check the class average.
Mike Pearson 2485 SS Last edited by Mike Pearson; 03-24-2023 at 01:38 PM. |
#35 |
Liked 587 Times in 163 Posts
Couple of questions, is Indy going to keep AHFS in this year? If so it would almost certainly get a trigger there at some point. There is plenty of season left though so it's way early to predict who or how many will get a HP increase.
Is the 1969 350/300HP combo that much worse and what parts are different than the 255 version? Point being if it's an intake manifold change and that is not as favorable maybe you can run that combo at the faster races typically, I don't have a horse in that race anyway Last edited by rboyle; 03-24-2023 at 01:55 PM. |
#36 | |
Liked 867 Times in 165 Posts
1189 F/SA Defunzalo Racing Enterprises |
#37 |
If you have five .700 runs and you make a 1.20 run you will not get HP. The more .700 runs you bank, the more times you can let it hang out. Obviously, that only applies if everyone running your combination follows the same plan....
#38 |
Liked 419 Times in 85 Posts
Daren laid out the answer spot on. If you bank your average at .70 under, when you go 1.15 it won’t bite you. If you plan on class racing or winning a heads up in the eliminator and don’t want to move classes next year, then they have laid out how to play the game with their bat, ball, glove and field.
#39 |
Just keep in mind that you need enough .700 runs to cover each fast run that you make...
#40 |
Liked 388 Times in 60 Posts
Good post Daren -- This is the problem with this whole program . Someone has 1or 2 triggers in March already , and they will have to throttle-stop their car the rest of the year, and hope everybody does the same. Doesn't look like a good way to race to me !!! I have no interest to run my car that way.
