Liked 3 Times in 2 Posts
To all, anyone have a good guess at a pinion shim for an oem 3.31 gear in a 12 bolt? There’s nothing scribed on the head of the pinion or ring gear. I could be wrong, but I feel like there had to be a quick reference when gm was setting up hundreds of rear ends a year back in the day. Any help is much appreciated. (NOTE: I did find documentation that said 12 bolts got a .030 shim).
#2 | |
Liked 976 Times in 311 Posts
Liked 90 Times in 52 Posts
Back in the 60.s I did lots of GM muscle cars with 12 bolts & typical shims from .028 to .032 ..start with the .28 & old trick to prevent bearing from getting wrecked on & off many times to change shim is to heat the bearing up to expand so it slips on & off off easy
Banned
Liked 179 Times in 89 Posts
I use the reference when I'm having a problem setting up a ring and pinion or I do not have access to the original shim or the old gear was not set up correctly.
GM .035 FORD 8"-9" *020 FORD 8.8"-7.5" .030 ALL DANA'S .035 8 3/4 X 1 3/4 PIN .090 8 3/4 X 1 7/8 PIN .020 MOPAR 9 1/4 .020 |
12 bolts usually take the following, in my experience:
2, 3 ratios...mid to high .020's 4, 5, 6 ratios...low to mid .030's
Liked 172 Times in 46 Posts
.026 to .028 will get you close. Remember when setting a used gear set that it is highly possible that you will not see a good pattern. you can get close adjust backlash a little on the loose side monitor noise on coast adjust if necessary.
Dirk Olson 5036 STK |
Liked 800 Times in 237 Posts
Doing a new set, .030-.032 is my default. On a used set, I'll hedge thinner by a couple thou. and pay more attention to the coast side. A bit of red Loctite on the pinion shaft where the front bearing registers and eliminate the crush sleeve.
"That'll never work....." Last edited by Alan Nyhus; 06-02-2023 at 04:38 PM. |
Thanks everyone. We’re on the right track for sure. I set it up with a .030 and based on the master housing depth of 4.670, it’s dead nuts on (pinion depth of 2.755 plus the thickness of the pinion head 1.915 equals 4.670).
That's fine but pattern and backlash are what matter.
