Old 07-02-2023, 01:53 PM   #1
KRatcliff
Liked 534 Times in 143 Posts
Default Hemi splined input shaft wanted
I need a Hemi splined input shaft with a .585" (GM) pilot diameter. I struggle putting in my G Force using the plastic clutch alignment tool. I guess the fortunate thing is that I haven't broken one yet so I would have my own.
I probably jinxed myself.
KRatcliff is offline   Reply With Quote
Old 07-03-2023, 08:10 AM   #2
Run to Rund
Liked 56 Times in 29 Posts
Default Re: Hemi splined input shaft wanted
I got a used input with a damaged bearing area from Jerico years ago. Either they or G-force might be able to sell you one. I also cut the heads off two long bolts to use as a pilot to help align and slide the trans into place on the bell housing. I cut screwdriver slots in the ends to facilitate removing them after the trans is installed.
Old 07-03-2023, 11:11 AM   #3
KRatcliff
I got a PM with a lead on one and I may call Jerico if this doesn't work out. I have asked Paul a few times at G-Force, but he hasn't been able to find a used or broken one in his shop.
Old 07-03-2023, 11:59 AM   #4
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I gave up looking for an input and just had a machine shop turn down a hunk of bar stock...you don't need the splines. Been using it for 10 years now. Just a thought.
Paul Merolla is offline   Reply With Quote
Old 07-03-2023, 12:05 PM   #5
KRatcliff
I think that is the route I may go.
Old 07-03-2023, 01:23 PM   #6
older racer
Liked 68 Times in 26 Posts
i did same, used aluminum shafting, no splines works great and cheap.
older racer is offline   Reply With Quote
Old 07-05-2023, 11:37 AM   #7
Adger Smith
Liked 880 Times in 311 Posts
If you are having problems with alignment with the plastic just get it close and put someone in the car and release the clutch as you are putting the trans into the splines. That floats the disc and it should self align, esp if you have the trans on slides or dowels.
Adger Smith (Former SS)
Old 07-05-2023, 01:23 PM   #8
KRatcliff
That is what I generally do when I am having trouble, but my alpaca isn't always available and I have to do it alone.
Old 07-06-2023, 11:55 PM   #9
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Rob Youngblood @ Advanced Clutches has machined aluminum clutch alignment tools with splines and interchangeable pilot tips.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Search this Thread:
Advanced Search
