Old 08-24-2023, 11:35 AM   #1
Kenney Kelley
Liked 72 Times in 36 Posts
Default Decal Removal
How does one remove Decals from an aluminum Trailer without messing up the paint
Thank You Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 08-24-2023, 11:55 AM   #2
Mike Gray
Mike Gray's Avatar
Liked 703 Times in 203 Posts
Default Re: Decal Removal
I took 5 dealer decals off my new ATC trailer. I used my heat gun to warm them up a little and they peeled right off in one piece. My trailer is not painted it appears to be an anodized finish.
Mike 7570 A/SA
Old 08-24-2023, 12:08 PM   #3
Liked 5,137 Times in 1,960 Posts
Be careful . HF type heat guns are too hot, IMO.
Use a hair dryer, if you've got one. Peel at a sharp angle,..slowly .
Then use a rag with some gas to get the glue off.
If It's white , baked on aluminum, you won't hurt it. If it's paint out of a spray gun... No tellin' what could happen.
Old 08-24-2023, 12:38 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
put it out in the sun and spray them around the edges with WD40 . it takes a little time to get going but once you can get it behind the edges, they come off pretty good , with no damage to the paint.
It also works really well for cleaning up the glue residue left behind.
Old 08-24-2023, 09:51 PM   #5
kirk
Liked 5 Times in 4 Posts
I also like to use those plastic razor blades to get under the decals, and get things started without the risk of paint damage
kirk is offline   Reply With Quote
Old 08-24-2023, 10:08 PM   #6
CMcAllister
Liked 920 Times in 259 Posts
Hair dryer, WD.
Old 08-25-2023, 12:15 PM   #7
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
I use lighter fluid for glue residue.
Bob Don 128 SS
Old 08-25-2023, 07:06 PM   #8
JGrossijr
JGrossijr's Avatar
Liked 463 Times in 60 Posts
Default Re: Decal Adhesive Removal
This is the best adhesive remover I have ever used and it is easy on paint. It works great for removing rubber and black specks from the burnout box too.
Name:	3M General Adhesive Cleaner (5).jpg
JGrossijr is offline   Reply With Quote
