Old 11-24-2023, 09:32 PM   #1
Ron Miller
Liked 13 Times in 7 Posts
Default Wanted suggestions how to create low drag Wilwood brakes
Guys,
I'm looking for suggestions on how to create low drag brakes. I have Wilwood 4 piston caliper brakes front & rear on my Gen 3 GT/DA 92 Camaro. Is there a kit one can buy? The TDM brakes are out of the question.
Thanks for looking,
Ron Miller is offline   Reply With Quote
Old 11-24-2023, 11:03 PM   #2
GTX JOHN
Liked 2,493 Times in 700 Posts
Default Re: Wanted suggestions how to create low drag Wilwood brake
I shim the caliber with spacer to make sure they are centered
on the disc properly (usually they are not). They still have more
drag than the more expensive brands that my son runs on his cars!
John Irving
741 Stock
741 Super Stock
Old 11-25-2023, 06:51 AM   #3
SGSST109E
Liked 126 Times in 61 Posts
As well as making sure the caliper is center I have small stiff springs I put between the pads so the cotter pin holds the springs in place.
SGSST109E is offline   Reply With Quote
Old 11-25-2023, 09:40 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Ron Miller View Post
Guys,
you buy Mark Williams brakes.
Old 11-25-2023, 10:06 AM   #5
MR DERBY CITY
Liked 8,205 Times in 1,536 Posts
Or Lamb brakes ….There are always budget minded racers that will take the Wilwood’s off your hands ,,..Lamb brakes = $$ well spent ….
Old 11-25-2023, 10:15 AM   #6
1320racer
1320racer's Avatar
there's good reason why you won't find wilwood brakes installed on any car built for drag racing by a professional chassis shop
Old 11-25-2023, 11:14 AM   #7
Mark Ugrich
Liked 71 Times in 38 Posts
Doesn’t Wilwood offer a low drag “ o” ring to replace the square cut seals in the calipers?
Old 11-25-2023, 11:24 AM   #8
joespanova
Liked 13 Times in 11 Posts
Making sure the calipers are centered is a no brainer , but switching to drilled rotors was the best thing I did. No more drag. This and the right pads.
Mine are Wilwood.
Old 11-25-2023, 12:05 PM   #9
Ron Miller
Mark,
I did look yesterday and I did'nt see any. I will call Monday.
Thanks for the reply,
Old 11-25-2023, 12:12 PM   #10
Ron Miller
Ed,
What have you been up to? I have seen you post in a long time. Do you still have the Firebird?
