#81 |
Liked 1,230 Times in 346 Posts
It is my understanding that AHFS was created and used for getting particularly advantageous combinations back in line with other combinations in the same class. So that A/SA was not littered exclusively by 1st generation Camaros, but so that all combos that were eligible to run A/SA overtime would fall in to line with one-another and those that put in the time and effort to excel would be able to do so, while others with less funds or without the same work ethic would fall behind. I'm good with that, it seems fair. Cars that can more easily take advantage of, or benefit more from rules changes or technology improvements should be penalized as different combos in the same class cannot keep up as the improvements given to some combinations are not viable for others. As I said, that seems to be the purpose of the AHFS.
It was not designed to punish those of you who work extremely hard and spend 10s of thousands of $$ on your program to make it quicker, qualify better, win class, and win heads up races should you have one. That is why the AHFS uses an aggregate average of every car in the country running that combination. If one person is excelling in that combination while others toil and struggle, that person should be rewarded for their hard work and dedication by being left alone, while the others are not punished for working hard to get under the index at all, like myself. To my understanding, that is the AHFS system in essence. The artificial lowering of indexes makes no sense to me. Not only does it substantially raise the cost of entering the sport, but it rewards combinations that, if left alone, would be given HP and fall back into line with other combinations in their class. If indexes had been lowered before this past season, I would never have built my stocker to begin with as a 24 year-old (25 now) on a shoe string budget. I believe the fastest I went all year this past year was MAYBE -.35 under and I had a ball. I hope they don't remove me from competition.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#82 |
Liked 207 Times in 44 Posts
All lowering the indexes does is keep people like Dawson from competing. It also makes NHRA job easier by not policing the combo's that need HP adjustments whether up or down.
That's my take. People that qualify high will still be there, just not the bigger number under. Been there done that Mark Lewis |
#83 | |
#84 | |
Liked 209 Times in 50 Posts
You should also have to have a Minimum and Maximum car count. Need at least 20 runs to get HP off. And take the Top 70% to add HP
Brian Anderson 5058 B/SA 99 Chevy Camaro SS |
#85 |
Liked 595 Times in 136 Posts
Huge congratulations to Avery for looking at real numbers, though as he mentioned, may be skewed by people detuning to game the system.
For something like this that makes a major impact in how races turn out, the NHRA should have been doing (and publishing this) since day one. But sadly, the outcome they're looking for is 180 out from what racers want. |
#86 | |
Liked 80 Times in 19 Posts
Year # of Cars On Q Sheet Top Qualifier Bottom Qualifier in Field Average under index Total Total Runs Counted Class Runs Average Class Runs Count Year # of Cars On Q Sheet Top Qualifier Bottom Qualifier in Field Average under index Total Total Runs Counted Class Runs Average Class Runs Counted 2019 139 -1.762 -0.675 -0.883 690 -0.936 2020 129 -1.355 3.446 -0.794 474 -0.871 2021 132 -1.104 -0.208 -0.747 528 -0.774 2022 141 -1.690 -0.366 -0.853 682 -0.933 2023 139 -1.640 -0.599 -0.881 698 -0.946 2024 148 -1.626 -0.607 -0.822 722 -0.833
Avery G. McLawhorn 2166 Super Stock Last edited by AveryMcLawhorn; 11-12-2024 at 02:49 PM. |
#87 |
Liked 449 Times in 98 Posts
People seem to be missing the point that gaming of the AHFS is rampant resulting in the following problems:
1. The AHFS is not functioning as intended to bring parity 2. With so many cars letting off at 1000' its beginning to look like a .90 category and losing fan appeal. 3. Its not fun for performance oriented racers to detune their cars most of the year to lower their average so they can safely run fast on just a few runs each year. 4. Stock and SS are losing their appeal to performance oriented racers which may be hurting participation of long time racers 5. Due to weak tech, some racers are claiming combinations they do not have, but willing to hurt the HP rating on 6. If a racer decides to bomb an engine HP rating, many other racers are hurt financially and competitively through no fault of their own I am sympathetic to those that are trying to race on a tight budget or chose a race car that hasn't had the same level of benefit of NHRA approved aftermarket parts. But I do appreciate any attempt by NHRA to rectify the above problems. I like lowering the stock indexs 3 tenths, with the same -.86 trigger, as a simple way to allow me to run the car fast and have more fun. That said, their are certainly numerous other tweeks the NHRA could do such as raising the trigger to -1.0 and lowering indexes less that could work. |
#88 |
Liked 7,813 Times in 1,748 Posts
Gee, where ever did you get that idea?
#89 | |
I get everyone wants to go fast at Indy but it is really the only race where there is something on the line worth getting hit for and we don't even count that data! Let's face it if you got a car running more than 1.20 under at Indy it needs refactoring if you're trying to establish parity.
#90 |
Liked 36 Times in 13 Posts
NHRA can change whatever they want, but the AHFS will never work because the NHRA doesn?t incentivize racers enough to penalize themselves. It will only work if they have it at events like Indy, and that ruins all of the fun. Racers aren?t going to penalize themselves for no reason, and NHRA won?t fix combos as they need adjusted, so we will just continue to make meaningless tweaks to the system.
