Old 09-19-2008, 09:10 PM   #21
Joe Demarais
Joe Demarais's Avatar
Default Re: another aa/sa chevelle
Thanks tony, it good to know that i'm not just another pretty face!!!!!
Joe Demarais SS
Joe Demarais is offline   Reply With Quote
Old 09-19-2008, 09:45 PM   #22
Bob Rice
Alan,
Here's a picture of Tucker driving Ronny Traffanstedt's 65 Chevelle wagon. He also drove a white 66 Chevelle wagon that also had the "Revenge" name on it. I'm pretty sure that he also drove another 65 Chevelle wagon at Blaney, SC in 76. I'm thinking that it was white with red and blue trim.
Bob Rice
Old 09-19-2008, 10:57 PM   #23
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
Boy, that's a great photo-notice the slick is all wrinkled, but the nose hasn't lifted yet-talk about the shutter opening at exactly the right moment to get that view!!
Old 09-19-2008, 10:58 PM   #24
larry lomascolo
Guest
Posts: n/a
Originally Posted by Joe Demarais View Post
The problem started at bir then finished up at earlville where nhra made the decision. I think it may have something to do with that wishbone piece on top. Kevin says it has to be changed to make them happy. If you have that suspension better check what has to be done, i t sounds like they are going to check in div 5, i talked to a tech guy.
Mark Faul runs the wishbone Wieb upper control arm also ,do not no if he has had a problem with tech?
Old 09-20-2008, 10:03 AM   #25
Joe Demarais
There are lots of those systems out there, there were even a few at earlville besides kevin, no one else had a problem, but what i heard, there could be a problem in the future, if you see a tech man with a mirror or knee pads walking around staging, you probably know what their doing
Joe Demarais SS
Old 09-20-2008, 11:12 AM   #26
K Stubbs
Liked 20 Times in 3 Posts
You dont have to have the trickest rear suspension on a coil spring car to make it work anyway, the main thing is to keep your rear lower control arms parallel and not work against each other. That is where the twist comes from, its no different than a four link type of rear suspension which most people use with an anti roll bar. This can be achieved on a chevelle or any other coil spring car by tying the lower control arms together, which were 1 5/8 .083 chromolly, with tubing. It looks like a thicker sway bar, to keep them moving at the same time and in the same direction. I also tied that bar into the front of the rear lower control arms, creating the wishbone, and no air bags. My A/SA chevelle I was running passed tech at Indy with Tech guys under it for an hour in 99 but maybe the rules have changed since then.
Kevin
K Stubbs is offline   Reply With Quote
Old 09-20-2008, 11:31 AM   #27
Jim Cimarolli
Liked 166 Times in 46 Posts
Wink Re: another aa/sa chevelle
Kevin!
Didn't Pee Paw Stubbs have that same thing "back when he was runnin' that 'Ol Biscayne" ?
Jim Cimarolli is offline   Reply With Quote
Old 09-20-2008, 11:40 AM   #28
K Stubbs
Originally Posted by Jim Cimarolli View Post
Kevin!
Jim,
Dont laugh if my new camaro comes out looking like a 66 Biscayne!
Kevin
Old 09-20-2008, 12:09 PM   #29
Mark Faul
Liked 43 Times in 9 Posts
I've had the tech guys lay under the back of my Chevelle for about 14 minutes once at tech, but was told then that as long as it could just be unbolted and drop out of the car, it was good to go.
If you see that, I'd get the hell out of there!!!
Mark Faul is offline   Reply With Quote
