Old 05-19-2007, 02:07 PM   #1
camaroracer
Default Front shock problem
I have a 67 camaro. I have a set of single adj shocks. Problem is on the pass side when i try to install shock it moves thru the lower control arm then seems to bottom out. So far i have had to compress the spring a bit to get the shock stud up thru the hole. This car has been aligned by a very smart super stock racer and he didn't see anything obvious.
One more thing, i bought the car with competition eng front shocks and i remember the stopper was ground down. It's obvious to me they were having the same problem.
Thanks a lot guys and gals. I just love this site.
David
one more thing, everything is stock control arm wise, etc.
camaroracer is offline   Reply With Quote
Old 05-19-2007, 02:41 PM   #2
Jeff Lee
Guest
Posts: n/a
Default
My guess is the spring has been altered for lower ride height (heated, cut or intentionally made).
NHRA #7494 SS/H
1970 AMC AMX
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
JeffLeeAzRealty@Qwest.net
602-418-9797
Old 05-19-2007, 02:43 PM   #3
camaroracer
Default
They are small block moroso trick with a coil cut out
Old 05-19-2007, 02:47 PM   #4
camaroracer
Default
And to boot no matter what spring over the few years I have had the car
Same problem. Only on the pass side. Wouldn't this problem possibly show up on both drivers and pass??
Old 05-19-2007, 08:22 PM   #5
Brian Holcombe
Default
OK, so at Full extension you cant put the shocks in? that means that ethier the shocks arent long enough, or that you need to adjust the stops in your upper control arms
Brian
Brian Holcombe is offline   Reply With Quote
Old 05-19-2007, 10:10 PM   #6
camaroracer
Default
Brian,
I run spacers to drop the shocks off the lower control arm mount enough to expose the adjuster.
Old 05-20-2007, 12:37 PM   #7
Brian Holcombe
Default
Oh, dont do that you'll limit you're front end travel, and top out the shock on every pass (which damages the shock).
this is what i did to cure that problem:
[IMaGe]http://i27.photobucket.com/albums/c181/SpeedyGoomba/Shockmod.jpg[/IMaGe]
Old 05-20-2007, 10:04 PM   #8
camaroracer
Default
Brian,
I think the gentleman that built me the one off shocks used the wrong shock bodies and that's why i use the spacers. I still have 6 + inches of travel last time i checked.
Old 05-20-2007, 10:08 PM   #9
Brian Holcombe
Default
As long as the shocks arent topping out they're fine.
Old 05-20-2007, 10:12 PM   #10
camaroracer
Default
Thanks a lot Brian That set up you run looks awesome. Do you need the lower control arm to make that deal work, i can't tell
