Old 05-15-2007, 11:29 PM   #11
Jeff Goss
Jeff Goss's Avatar
Default
Thanks alot for the good info.
I think what it comes down to is I'll just need to try it. Too many variables in each combination for my small brain-LOL!
Jeff
Jeff Goss is offline   Reply With Quote
Old 05-17-2007, 08:10 PM   #12
matt beumer
Default
I looked at Sunoco's and VP's web sites to compare specs. on there fuels and the #'s posted above are not the same as the #'s given by the manufacturers on there web sites. The main difference being RVP.
VP C-12 has a RVP of 7.30,
Sunoco Supreme has a RVP of 6.3
Octane #'s are similar 108 to 110
Spec. Gravity are similar .717 to .715
My question is how well does the Sunoco Supreme (BLUE) work in higher compression motors? I.E., 396/375 stocker
THX--Matt
matt beumer is offline   Reply With Quote
Old 05-17-2007, 11:05 PM   #13
Steve Reynolds
Default
Jeff, I have been using Sunoco for the past two years in my Super Street Nova, and haven't seen an issue with horsepower.
I did have a conversation about the difference in VP and Sunoco, with Mark Kidd of Twin Falls Idaho, who has spent alot of hours testing each fuel on his Dyno, and he claims that the VP in good for approx. 7 horsepower in a high compression test mule.
I still dont see any difference in my case, running 13-1 in a small block Chevy.
However, last year a good friend of mine at the first division race (Div 6), did have a problem with Sunoco passing the fuel check with his L/SA Malibu wagon.
S/ST6608,S/Pro D608
Steve Reynolds is offline   Reply With Quote
Old 05-18-2007, 12:26 AM   #14
Adger Smith
Liked 880 Times in 311 Posts
Default
Steve,
Mark Kidd sees the same HP improvement I have seen in High compression engines. That could be due to VP reformulating the C-12 a couple of years ago. It seems to work better in higher compression engines now. I would assume there is little difference in low compression engines. Lower compression engines might even do better with the lower octane fuel.
In testing I have expereienced a 26 Hp difference in VP C-14 & Sunoco Maximal in the Splayed Valve V-6 I run. This V-6 engine is a very high RPM & high compression engine. It just likes the VP C-14, but makes even more power on VP C-25. Just try the fuel & see if it works for your combination. Each engine & engien combination could be different. I guess that is why VP lists over 50 different fuel mixtures.
Adger Smith
Adger Smith (Former SS)
Old 05-18-2007, 12:36 AM   #15
Jeff Goss
Jeff Goss's Avatar
Default
Thanks Steve.
I think my lower compression will make the two fuels about equal.
I am a little worried about fuel check. I guess if we see a big DQ next to my name on the qual sheet in Mission we'll know why-LOL!
I have met your friend with the Malibu wagon-in Boise a few years ago. Good guy!
Jeff
Old 05-18-2007, 01:21 AM   #16
Mike Galuk
Default
Jeff, don't worry about passing fuel check. I have been racing with Greg for about four years now and have never seen him fail. Good luck, Mike
Mike Galuk
JOE COOL RACING
Stock-2080
Mike Galuk is offline   Reply With Quote
