Old 11-08-2008, 01:11 PM   #1
R Hoffman
R Hoffman's Avatar
Default 82-92 F-body stock rear sway bar
What size rear sway bar is recommended for a third-gen Camaro stocker? I've noticed that GM offered a couple of different sizes.
DTS 12-bolt, S&W suspension, Eibach drag launch springs and bag.
Thanks for any Info!
Bob
n/a
R Hoffman is offline   Reply With Quote
Old 11-08-2008, 11:15 PM   #2
zracer305
Default Re: 82-92 F-body stock rear sway bar
I don't know of many guys running a rear sway bar. Look into getting a nice anti rollbar.
zracer305 is offline   Reply With Quote
Old 12-03-2008, 11:13 PM   #3
OWNSS
If you have no restrictions on what you can run go with the Spohn 1" drag bar. If you can only run stock parts then looking into the 87-92 GTA Trans Am rear sway bar or the 88-92 1LE Z28/Trans Am sway bar. They are the 2 largest GM offered on the cars from the factory. The GTA bar is much easier to find compaired to the 1LE.
1999 Camaro SS
11.14@124 1.57 60ft
OWNSS is offline   Reply With Quote
Old 12-04-2008, 08:52 PM   #4
R Hoffman
R Hoffman's Avatar
Smile Re: 82-92 F-body stock rear sway bar
OWNSS...Thanks for the reply...I plan on installing S&W's anti-roll bar in the future but for now I'm going to use a factory sway bar...
I've looked under quite a few of these cars at divisional events and noticed that some racers still use a factory type sway bar.
I'll start searching for one of the bars you mentioned.
Thanks ! Bob
n/a
